[mapserver-users] Mapscript newby ..
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 13 08:49:01 EST 2002
Giorgio,
Your mapserv does not have support for GIF images so you need to make
sure that you map and symbol files does not reference any. I believe the
standard demo.map does.
So ...
you need to change all the GIF references to PNG and convert all the GIF
files to PNG. See:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerDemo
for more info.
-Steve W.
Giorgio Volpe wrote:
> I'm tring to use mapscript but i stop at the first step!
> draw() saves an empty file using:
> #!/usr/bin/perl
> use mapscript;
> $map = new mapObj('demo.map') or die('Unable to open mapfile.');
> $img = $map->draw() or die('Unable to draw map');
> mapscript::msSaveImage($img, "ex.jpg", 3 , $map->{interlace},
> $map->{transparent}, 95);
> where demo.map is itasca example map.
> Where is the problem? How can i debug this?
> My mapserv -v returns:
> MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
> Thanks in advance
> Giorgio
