[mapserver-users] Windows 98 running PHP/Mapserv: gmap75.phtml does
not work.
Daniel Morissette
morissette at dmsolutions.ca
Fri Mar 15 08:04:14 EST 2002
Jan,
You get this error because you are running PHP4.1.1 but your
php_mapscript_35.dll is compiled for PHP4.0.6. There is no PHP4.1.x DLL
available yet... we're still working on resolving some PHP4.1.x
issues... hopefully one will be available soon.
Daniel
Jan Mantkowski wrote:
> Hi all,
> i run into a problem installing Mapserver and PHP/MapScript at my notebook.
> This is what i did:
> Windows 98 SE, german language
> FoxServ2.1.exe (WAMP system right out of the box providing php4.1.1, mySQL
> 3.23 Apache 1.3.22)
> PostNuke (cvsbuild03132002.tar.gz) to test it. It runs perfect.
> Mapserver (ms35png.zip).
> Then i changed the php from module to cgi by editing the httpd.conf:
> Add:
> ScriptAlias /php/ "c:/FoxServ/php/"
> Action application/x-httpd-php "/php/php.exe"
> AddType application/x-httpd-php .php .php4 .phtml
> Delete:
> LoadModule php4_module C:\FoxServ/php/sapi/php4apache.dll
> AddType application/x-httpd-php .php4 .php .htm .php3 .inc
> AddType application/x-httpd-php-source .phps
> I restarted the server and run phpinfo.php.
> In the first table the Server API line changed from:
> Server API Apache
> to
> Server API CGI.
> Again, PostNuke did very well.
> itasca3.5.tar.gz.
> To make it work i converted all grafics from .gif to.png and changed the
> demo.map and demo_init.html to call the .png files instead of .gif files. It
> runs perfect.
> php4.0.6_php_mapscript_35_release.zip
> Installed as told.
> Now i installed gmap-ms35-release.zip and run into problems.
> Whenever i run
> c:\foxserv\www\gmap\htdocs\gmap75.phtml
> i get this error message:
> Warning: Unable to load dynamic library
> '\php\extensions\php_mapscript_35.dll'
> So i tryed to change the php.ini:
> extension_dir = \php\extensions\
> But what directory i choosed, it does not work.
> Please help me.
> Thanks,
> Jan Mantkowski
> PS:
> I am german, so there might be a few errors in this e-mail.
> Luton (near London), England
> vormals
> Hamburg, Deutschland
> e-mail: jan.mantkowski at gmx.de
