[mapserver-users] drawing layer with user names from mysql table
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 20 08:09:46 EST 2002
Jan,
$map appears to be undefined at line 28.
-Steve
Jan Mantkowski wrote:
> Hi all,
> i have not been able to make my script run right now.
> Please help me.
> Jan
> PS:
> If someone has a complete working example of how to display data from mysql
> table as a layer of a map please mail it to me.
> I always get this error:
> Fatal error: Call to a member function on a non-object in
> c:\apache\htdocs\pn_71\html\modules\map\index-standalone3.php on line 28
> line 28 is: $layer = $map->getLayerByName( $layerName );
> This is my data in the mysql table:
> -0.1271 51.5063 Jan London
> -3.7057 40.4203 Jose Madrid
> 2.3453 48.8547 Madeleine Paris
> 9.9898 53.5548 Fritz Hamburg
> This my php script:
> <?php
> // load .dll`s, so there is no need to edit the php.ini.
> // but you need to put this files in your /php/extensions folder
> dl("php_mapscript_35.dll");
> dl("php_proj.dll");
> dl("php_dbase.dll");
> //variables
> GLOBAL $map;
> GLOBAL $image;
> GLOBAL $layer;
> $layerName="PNUsers";
> //mysql_q
> $db = mysql_connect("localhost", "root", "");
> mysql_select_db("Rogue",$db);
> $results = mysql_query("SELECT * FROM nuke_map",$db);
> if ($results === false) die("failed");
> //display result of mysql query on screen
> while ($show = mysql_fetch_array($results, MYSQL_ASSOC)) {
> echo
> $show["pn_lon"]." ".$show["pn_lat"]." &nbs
> p; ".$show["pn_name"]."<br>\n";
> //drawPoints
> // Loop through result of point query and:
> while ($line = mysql_fetch_array($results, MYSQL_ASSOC)) {
> $pt = ms_newPointObj();
> $pt->setXY( $line["pn_lon"], $line["pn_lat"] );
> $pt->draw($map, $layer, $image, 0, "TEST");
> $layer->set('status', MS_ON);
> $layer->draw($image);
> //showmap
> $map = ms_newMapObj("data/europe.map");
> $image=$map->draw();
> //$layer->draw($image);
> $image_url=$image->saveWebImage(MS_PNG,1,1,0);
> echo "<img src=\"".$image_url."\">";
> Thanks,
> Jan
> europe.map Type: unspecified type (application/octet-stream)
> Encoding: 7bit
