[mapserver-users] Chekc vs select
    Vu Pham
    vu at sivell.com
    Wed Mar 20 20:11:58 PST 2002
Thanks, Antti. I see what you say now. It is the parameter for the HTML,
not the mapserv. I just changed the select/check and saw how it affected
the program. In the multiple select, I could see the selected item is
hightlighed.
Vu
-----Original Message-----
From: Antti.Roppola at brs.gov.au [mailto:Antti.Roppola at brs.gov.au]
Sent: Wednesday, March 20, 2002 9:56 PM
To: vu at sivell.com
Subject: RE: [mapserver-users] Chekc vs select
It depends on the HTML widget you are using to
indicate that a layer should be displayed.
In the HTML specification, an item in a <SELECT> gadget is "selected"
while an item in a checkbox gadget is "checked". Naturally, Mapserver
needs to obey the HTML specification.
Antti
Sent: Thursday, 21 March 2002 1:09 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Chekc vs select
Hi all,
What is the different between layername_check and layername_select ? My
example may be very simple and I can not find the difference between
these two.
Thanks,
Vu
More information about the MapServer-users
