[mapserver-users] Fwd: setfilter
Daniel Morissette
morissette at dmsolutions.ca
Fri Mar 22 17:46:32 EST 2002
> From: Patricio Gigoux <pgigoux at munistgo.cl>
> I have tested it from map file and no problem, but when I had tried from PHP
> file give me troubles or better said have displayed nothing. I have used the
> next whitout success:
> layer->setfilter("CAMPO='$var'");
I believe the correct syntax would be:
$layer->setFilter("([CAMPO]='$var')");
You need:
- Square brackets around field names
- Parenthesis around the expression to indicate that it's a logical
expression.
Note that since you're evaluating a single attribute value, then using a
constant expression instead of a logical expression would be more
efficient:
$layer->set("filteritem", "CAMPO");
$layer->setFilter( "\"$var\"" );
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
