[mapserver-users] Railroad and dual carriage way styles
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 18 22:27:47 EST 2002
SYMBOLSET [filename] should go in your map file and [filename] should be
a separate file the has your symbols in it
OR
Just put the symbol definitions in the map file without the SYMBOLSET
keyword.
-Steve W.
TCHaddad wrote:
> Mapservers,
> In the archive I found the following exmaple for "Railroad and dual carriage way styles":
> http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0112/msg00142.html
> However, when I add the symbol 'circle' to my symbolset, and refer to it in my map file, it bombs out. Conversely, when I comment out the map file ref. to 'circle' and the symbol in the symbolset, everything works again...
> I've attached my symbolset and the layer def. below.-- What am I doing wrong? (Apologies if it is something obvious...)
> TH
> MSS 3.5, WIN2k, IIS
> LAYER
> NAME Main_Roads
> GROUP roads
> TYPE LINE
> DATA "d:\gis\roads"
> STATUS OFF
> CLASS
> SYMBOL 'circle'
> COLOR 0 0 0
> SIZE 5
> OVERLAYSYMBOL 'circle'
> OVERLAYCOLOR 255 0 0
> OVERLAYSIZE 3
> END
> END
> SYMBOLSET
> Symbol
> NAME 'interstate_shield'
> TYPE PIXMAP
> IMAGE 'symbols/interstate.gif'
> TRANSPARENT 7
> END
> Symbol
> NAME 'us_highway_shield'
> TYPE PIXMAP
> IMAGE 'symbols/ushwy.gif'
> TRANSPARENT 1
> END
> Symbol
> NAME 'state_highway_shield'
> TYPE PIXMAP
> IMAGE 'symbols/sthwy.gif'
> END
> Symbol
> NAME 'county_highway_shield'
> TYPE PIXMAP
> IMAGE 'symbols/ctyhwy.gif'
> TRANSPARENT 0
> END
> Symbol
> NAME 'circle'
> TYPE ELLIPSE
> FILLED true
> POINTS
> 1 1
> END
> END
> END # MapServer Symbol Set
