[mapserver-users] shpdmp under WIndows 98 does not work?
Jan Mantkowski
jan.mantkowski at gmx.de
Mon Mar 25 07:13:53 EST 2002
Hi list,
i try to change the Units of the europe example from Meters to DD.
So i am looking for the right Extents in DD format.
I noticed that i can do this by using shpdump.exe from the
shapelib129_bin_win.zip file.
So i copied all files from teh zip and europa.shp to the folder C:\a.
In a DOS box i typed
c:a\> shpdump.exe europa.shp
But all i get is an error:
"Programm had been terminated because of an error."
or something like that (its a german Windows 98, so i tranlated)
I also tryed
c:a\> shpdump europa but got the same error.
Any hints?
Can i use the shapelib.dll to do the same using php? How to do it?
Jan
Error message:
SHPDUMP verursachte einen Fehler durch eine ungültige Seite
in Modul SHPDUMP.EXE bei 0167:00404cf6.
Register:
EAX=00760e80 CS=0167 EIP=00404cf6 EFLGS=00010286
EBX=00530000 SS=016f ESP=0063fd44 EBP=0063fd84
ECX=00000000 DS=016f ESI=00000000 FS=1b3f
EDX=00760e80 ES=016f EDI=ffffffff GS=0000
Bytes bei CS:EIP:
8b 46 0c a8 40 74 05 83 c8 ff eb 3a a8 83 74 34
Stapelwerte:
00000000 8179c8c8 00401515 00000000 00000804 bff7a3a0 00650000 00750950
000006ac 00760e60 00760e40 00760e80 00000006 00000040 00000000 00000750
Jan
