[mapserver-users] Fwd: setfilter
Patricio Gigoux
pgigoux at munistgo.cl
Mon Mar 25 09:06:48 EST 2002
El Vie 22 Mar 2002 18:46, Daniel Morissette escribió:
> > From: Patricio Gigoux <pgigoux at munistgo.cl>
> > I have tested it from map file and no problem, but when I had tried from
> > PHP file give me troubles or better said have displayed nothing. I have
> > used the next whitout success:
> > layer->setfilter("CAMPO='$var'");
> I believe the correct syntax would be:
> $layer->setFilter("([CAMPO]='$var')");
> You need:
> - Square brackets around field names
> - Parenthesis around the expression to indicate that it's a logical
> expression.
> Note that since you're evaluating a single attribute value, then using a
> constant expression instead of a logical expression would be more
> efficient:
> $layer->set("filteritem", "CAMPO");
> $layer->setFilter( "\"$var\"" );
Thank you
my filter is ready, but it work with:
$layer->setFilter("([CAMPO]=$var)");
