[mapserver-users] shpdmp under WIndows 98 does not work?
Scott Carr
scottcarr at telocity.com
Mon Mar 25 14:28:38 EST 2002
shpdump {Shp File} > {file you want to save it as}
Replace curly braces with respective files.
This will dump all StdOut into the file you name.
Scott
Jan Mantkowski wrote:
>Frank,
>you are right i have that file.
>And it works. A hell a lot of data is displayed on screen for minutes.
>Thats it.
>I do not have a glue how to catch the data.
>I thought a .txt file will be created?
>Jan
>P.S.:
>By the way, can someone please send the dump of europe.shp to me?
>I want to go on with developing.
>-----Original Message-----
>From: Frank Warmerdam [mailto:warmerdam at pobox.com]
>Sent: Monday, March 25, 2002 4:29 PM
>To: Jan Mantkowski
>Subject: Re: [mapserver-users] shpdmp under WIndows 98 does not work?
>>Hi Frank,
>>here it is.
>>Hope you have a cable modem, or dsl at least.
>>By the way: I got the same error with stprklab.shp too.
>>Jan
>Jan,
>The problem is that you don't have the associated europa.shx file. I will
>modify shpdump to recover more gracefully. :-)
>I assume you do have the .shx file somewhere ... wherever you got the
>shp file, right?
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam,
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
Thanks
Scott Carr
OpenOffice.org
Whiteboard-Doc Maintainer
http://whiteboard.openoffice.org/doc/
