[mapserver-users] Nationalatlas Shapefile Projection
Sathiskumar Govindasamy
gsathis at yahoo.com
Fri Mar 22 11:50:02 EST 2002
Thanks guys. That was it. It works great.
-Sathis
Ed McNierney wrote:
>Sure - just use PROJ, the projection tool MapServer uses (available from
>http://www.remotesensing.org/proj). The "four corners" technique is a
>good start, but please remember that it won't always ensure that the
>entire original area is visible in the output area. But it's usually
>fine and you can tweak things from there.
> - Ed
>Ed McNierney
>Chief Mapmaker
>TopoZone.com
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
>Sent: Friday, March 22, 2002 8:22 AM
>To: Ed McNierney
>Cc: Sathiskumar Govindasamy; mapserver-users at lists.gis.umn.edu
>Subject: Re: [mapserver-users] Nationalatlas Shapefile Projection
>OK, so is there a utility that lets you say project the extents so you
>have new numbers for you map file? You would probably want to project
>all four corners of your extents and then take the exnts of the
>projected corners to be you new extents in the project space.
>-Steve
>Ed McNierney wrote:
>>Sathis -
>>Your EXTENT numbers are in the same units your output projection is
>in.
>>If you're displaying decimal degrees, the extents work. When you
>>project the output to LCC, the units change completely, and the EXTENT
>>numbers now specify a tiny little area that's nowhere near the United
>>States. That's why you get a blank image.
>> - Ed
>>Ed McNierney
>>Chief Mapmaker
>>TopoZone.com
>>From: Sathiskumar Govindasamy [mailto:gsathis at yahoo.com]
>>Sent: Thursday, March 21, 2002 9:26 PM
>>To: mapserver-users at lists.gis.umn.edu
>>Hi all,
>>To give a better idea about what I am trying to acheive, I have
>>explained little bit more in this mail than before. I wanted the
>>mapserver to generate the image of USA in the "lcc : Lambert Conformal
>>Conic projection" or "aea : Albers Equal Area" or which ever suits
>best
>>for US. I have the National Atlas US States shapefile statesp020.xxx .
>>The following is the map file.
>>NAME USA
>>STATUS ON
>>EXTENT -126 50 -66 24
>>UNITS METERS
>>SIZE 700 550
>>SHAPEPATH "data"
>>IMAGECOLOR 79 173 253
>>PROJECTION
>> "proj=lcc"
>> "lat_0=24"
>> "lat_1=50"
>> "lon_0=-99"
>>END
>>WEB
>> TEMPLATE demo.html
>> LOG demo.log
>>END
>># Start of symbol definitions (we're only using a few)
>>SYMBOL
>> NAME 'circle'
>> TYPE ELLIPSE
>> POINTS 1 1 END
>> FILLED TRUE
>>END
>># Start of layer definitions
>>LAYER
>> NAME statesp020
>> MAXSCALE 600000
>> TYPE POLYGON
>> STATUS DEFAULT
>> DATA statesp020
>> PROJECTION
>> "proj=latlong"
>> "ellps=clrk66"
>> END
>> CLASSITEM 'state'
>> CLASS
>> NAME 'Unwanted States'
>> EXPRESSION /'Virgin Island'|Puerto|Alaska/
>> OUTLINECOLOR 198 243 255
>> COLOR 198 243 255
>> END
>> CLASS
>> NAME 'State & Nation Boundary'
>> EXPRESSION /./
>> OUTLINECOLOR 180 180 180
>> COLOR 255 255 255
>> OVERLAYSYMBOL 'circle'
>> OVERLAYSIZE 2
>> OVERLAYOUTLINECOLOR 180 180 180
>> END
>> TOLERANCE 0
>>END
>>END
>>In the Map PROJECTION Section when I change the above shown on to
>>proj=latlong and remove lat_0 and other stuff, then the map shows up
>>correctly. But, when I have it as shown above, I just only see an
>image
>>with solid image color. Can someone tell me where I am making mistake
>>Thanks
>>Sathis
>>Kieran J. Ames wrote:
>>Sathis,
>>I'll share the little I know with you.
>>You need to investigate projections in general. Different projections
>>render
>>maps in different ways. If you have ArcView (what I use), you can take
>>your
>>UNPROJECTED DATA (Decimal Degrees) and PROJECT it. This will allow you
>>to see
>>what happens. If you can't do that, then you might post to the group
>and
>>ask
>>them what the best projection for this would be.
>>eg: if you want to show North America and NOT zoom in, you may choose
>>one
>>projection over another. Tell the group what you want to accomplish
>and
>>go from
>>there.
>>HTH.
>>Kieran
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020322/2fa5a2c9/attachment-0001.html
