[mapserver-users] Calling Mapserver from a Servlet
Harald Wehr
hwehr at hs-harz.de
Tue Mar 19 00:13:08 PST 2002
I try to use mapserver within a servlet. I successfully built the
library and java-classes (with "swig") and can compile erverything.
Things are working fine within a normal jvm.
Calling the same within a servlet only works two times. Then i get the
attached error message and tomcat crashes.
I doubt that the error is indeed in libgd as the error message says.
Using the mapscript-functions from a normal jvm works fine.
It seems to me that in a servlet there a some threads that are
responsible for the error.
Does anyone have some hints for me?
Harald
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020319/429a88d9/attachment-0002.ksh>
More information about the MapServer-users
