[mapserver-users] Fwd: querybyattributes
Patricio Gigoux
pgigoux at munistgo.cl
Thu Mar 28 08:46:12 EST 2002
Hi
yes, I need know what are the steps for use and get correct answer from
querybyattributes.
But i read from de documentation the next:
int queryByAttributes(int mode)
Query layer for shapes that intersect current map extents.
The query is performed on all the shapes that are part of a CLASS
that contains a TEMPLATE value or that match any class in a
layer that contains a LAYER TEMPLATE value.
Mode is MS_SINGLE or MS_MULTIPLE depending on number of results
you want.
Returns MS_SUCCESS if shapes were found or MS_FAILURE if nothing
was found or if some other error happened (note that the error
message in case nothing was found can be avoided in PHP using
the '@' control operator).
then I use:
layer->setfilter("[campo]=$var");
layer->querybyattributes(MS_SINGLE);
But it doesn't give me good result
How do I have to do it?
Thank you
El Mié 27 Mar 2002 17:32, escribió:
> ------------- Begin Forwarded Message -------------
> To: "Steve Lime" <steve.lime at dnr.state.mn.us>,
> <mapserver-users at lists.gis.umn.edu> From: "Lowell
> Filak"<lfilak at medinaco.org>
> Subject: Re: [mapserver-users] Fwd: querybyattributes
> Date: Wed, 27 Mar 2002 16:21:05 -0500
> queryByAttributes(mapObj,int mode);
> Is that what your looking for?
> Lowell F.
> The following message was sent by "Steve Lime" <steve.lime at dnr.state.mn.us>
> on Wed, 27 Mar 2002 11:25:40 -0600.
> > Received: from mail.state.mn.us
> > (state.mn.us [156.99.125.109])
> > by co5.dnr.state.mn.us; Wed, 27 Mar 2002 10:10:20 -0600
> > Return-Path: <root at localhost.localdomain>
> > Received: from lists.gis.umn.edu by mail.state.mn.us with ESMTP for
> steve.lime at dnr.state.mn.us; Wed, 27 Mar 2002 10:01:15 -0600
> > Received: from localhost.localdomain ([200.54.64.42])
> > by lists.gis.umn.edu (8.9.3+Sun/8.9.1) with ESMTP id KAA27241
> > for <mapserver-info at lists.gis.umn.edu>; Wed, 27 Mar 2002 10:01:32 -0600
> (CST)
> > Message-Id: <200203271600.g2RG0m802043 at localhost.localdomain>
> > From: Patricio Gigoux <pgigoux at munistgo.cl>
> > Reply-To: pgigoux at munistgo.cl
> > To: mapserver-info at lists.gis.umn.edu
> > Subject: querybyattributes
> > Date: Wed, 27 Mar 2002 12:00:41 -0400
> > MIME-Version: 1.0
> > Content-Type: text/plain; charset="iso-8859-1"
> > Content-Transfer-Encoding: 8bit
> > Can somebody said me what is the right form to use querybyattributes?
> > Thank you in advance
> > Patricio
> ------------- End Forwarded Message -------------
