[mapserver-users] Any examples of coordinate conversion web pages
Mark Giesbrecht
mgiesbrecht at geoarctic.com
Thu Mar 28 13:34:25 EST 2002
Hi There,
I'm trying to follow your example below, but I get the following error when I run
it:
Fatal error: Object expected as argument. in
e:\software\apache\htdocs\tmp\writeshaperectangle.php on line 40
my line 40 is:
$ret = pj_transform($pjlcc, $pjlat, $ingeox, $ingeoy);
I had read in the previous listing about the PROJ_LIB variable, but I'm not sure
where it points to.
Any pointers?
Cheers,
Mark
Assefa Yewondwossen wrote:
> Are yo using php ? If this is the case there is a module provided with
> php/mapscript (php_proj.dll/so) that you can use to do the conversion. The
> module basically gives you access to some functions of the Proj4 projection
> library used by mapserver. Here is an example of usage transforming from lcc
> to latlong:
> Later,
> <?php
> if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
> dl("php_proj.dll");
> else
> dl("php_proj.so");
> $projarray[0] = "proj=lcc";
> $projarray[1] = "ellps=GRS80";
> $projarray[2] = "lat_0=49";
> $projarray[3] = "lon_0=-95";
> $projarray[4] = "lat_1=49";
> $projarray[5] = "lat_2=77";
> $projarray[6] = "";
> $pjlcc = pj_init($projarray);
> $projarray2[0] = "proj=latlong";
> $pjlat = pj_init($projarray2);
> $lat = 45.25;
> $long = -75.42;
> $ingeox = 1537490.335842;
> $ingeoy = -181633.471555;
> printf("ret x = %f<br>\n", $ret["u"]);
> printf("ret y = %f<br>\n",$ret["v"]);
> $ret = pj_transform($pjlat, $pjlcc, $long, $lat);
> pj_free($pj);
> Tyler Mitchell wrote:
> > Hi gang, I want to put together a simple web page that allows a user to
> > enter lat/long and/or UTM coordinates and have them converted one to
> > another. Is anyone doing this already? If you are willing to share some
> > of the info with me, it would save me from reinventing the wheel. ;)
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056
> Fax: (613) 565-0925
Type: text/x-vcard
Desc: Card for Mark Giesbrecht
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020328/3a81a552/mgiesbrecht.vcf
