[mapserver-users] Reference obj & image file
Vu Pham
vu at sivell.com
Sat Mar 30 21:56:29 EST 2002
Thanks for everybody.
After using shp2img to create a gif file then converting to png file
and applying the correct parameter, I could be able to display the
correct reference.
Thanks again,
Vu
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Pushkar
Pradhan
Sent: Monday, March 25, 2002 11:33 AM
To: Vu Pham
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [mapserver-users] Reference obj & image file
Vu,
This must be happening because your gd doesn't support gif imgs.
Regarding your 2nd ques. I couldn't understand it so not able to answer.
Work around for 1st problem is to convert all gifs to pngs (which you
already did).
> Thanks, Steve. Is there any free app allow me to resize the shape and
> save ?
> Other questions :
> 1. when I use a gif file, I got this error msg:
> msDrawReferenceMap(): General error message. Unable to load GIF
> reference image.
> [ The path is correct, because if I change the filename, I get another
> error
> msDrawReferenceMap(): Unable to access file. (ilkane_ref.gif)].
> What may cause this ?
> 2. Then I tried a .png file, it does display the reference picture,
> is not usable as the doc states, or because my wrong parameter
> somewhere else ?
> Thanks,
> Vu
> From: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Stephen
> Woodbridge
> Sent: Saturday, March 23, 2002 7:32 AM
> To: Vu Pham
> Subject: Re: [mapserver-users] Reference obj & image file
> Vu,
> Your work-a-round to this problem was good, but there is a much easier
> way to do this that other might be interested in.
> If you want a reference image of say 200 x 200 then edit your map file
> and set the image SIZE 200 200 then use shp2img -m <mapfile> -o
> and you are all done!
> Oh, don't forget to change your SIZE back to its orginal.
> -Steve
> Vu Pham wrote:
> > Hi all,
> > I would like to use the Reference object. The doc says I need I gif
> > file for the reference image. Is there any way to help me to have
> > this
> > image file from the the shape file or any similar way without
> > manually
> > drawing ? I am very bad in drawing.
> > Thanks,
> > Vu
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
