[mapserver-users] raster creation & use
Lowell Filak
lfilak at medinaco.org
Fri May 3 11:47:32 EDT 2002
I think, judging from the bottom of your code the world file looks like:
0.00166666666666667
0
0
0.00166666666666667
-118.9
35.6
Correct?
I don't yet see why that doesn't work. How far off is the registration?
Lowell F.
The following message was sent by Ed McNierney <ed at topozone.com> on Thu, 02 May 2002 16:47:26 -0400.
> Joe -
> The order of elements in a world file is:
> X pixel size
> 0.0
> 0.0
> Y pixel size
> Left
> Top
> You seem to be writing the first four in the wrong order, no?
> - Ed
> Ed McNierney
> Chief Mapmaker
> TopoZone.com
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Joe Bussell [mailto:joe at otsys.com]
> Sent: Thursday, May 02, 2002 4:24 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] raster creation & use
> I have managed to create a set of png images using mapserver which
> constitute the tile set that I will later use for producing the final
> image product. I am apparently not producing the *.wld files correctly
> as the rasters do not properly align themselves when drawn.
> The procedure is as follows:
> determine how many cells to create based on a level
> for each cell
> generate a map
> get maps actual extent
> create world file
> I then use gdaltindex to create the shapefiles, then shptree to create
> an index. I believe that I am incorrectly assigning the world file
> elements.
> Is the pixelSize used for PNG files at all? Are there issues which
> I have failed to address?
> Following are the relevant subroutines in my tile production code.
> sub createTiles
> my %args =
> LEFT => -118.9,
> TOP => 35.6,
> BOTTOM => 33.4,
> RIGHT => -114.4,
> XDIM => 600,
> YDIM => 600,
> MAPFILE => 'td.map',
> OUTFILE => $ENV{PWD}.'/LA',
> LEVEL => 1,
> X_DIVS => 1,
> Y_DIVS => 1,
> @_,
> print "createTiles\n" if $verbose;
> my $deltaDegree = 1 / $args{LEVEL};
> my $xDivs = ceil( ( $args{RIGHT} - $args{LEFT} ) / $deltaDegree );
> my $yDivs = ceil( ( $args{TOP} - $args{BOTTOM} ) / $deltaDegree );
> my ( $x, $y );
> my $xDiv = ( $args{LEFT} - $args{RIGHT} ) / ($args{X_DIVS} + 1);
> my $yDiv = ( $args{BOTTOM} - $args{TOP} ) / ($args{Y_DIVS} + 1);
> my @files;
> print "xDIV=$xDivs yDIV=$yDivs \n" if $verbose;
> for ( $x = 0; $x <= $xDivs; $x++ )
> my $left = $args{LEFT} + $x * $deltaDegree;
> my $right = $left + $deltaDegree;
> for ( $y = 0; $y <= $yDivs; $y++ )
> my $pngFile = $args{OUTFILE} . "level" . $args{LEVEL} . "_" . $x . $y . '.png';
> my $wldFile = $args{OUTFILE} . "level" . $args{LEVEL} . "_" . $x . $y . '.wld';
> my $top = $args{TOP} - $y * $deltaDegree;
> my $bottom = $top - $deltaDegree;
> my $map = renderMap( LEFT => $left,
> RIGHT => $right,
> TOP => $top,
> BOTTOM => $bottom,
> XDIM => $args{XDIM},
> YDIM => $args{YDIM},
> MAPFILE => $args{MAPFILE},
> OUTFILE => $pngFile );
> push( @files, $pngFile );
> if ( $verbose )
> print STDERR "PNG file created: $pngFile $top $bottom $left $right\n";
> print STDERR "minx = $map->{extent}->{minx} maxy = $map->{extent}->{maxy} maxx = $map->{extent}->{maxx} miny = $map->{extent}->{miny} \n";
> $right = $map->{extent}->{maxx};
> $left = $map->{extent}->{minx};
> $top = $map->{extent}->{miny};
> $bottom = $map->{extent}->{maxy};
> my $xPixelSize = ($right - $left) / $args{XDIM};
> my $yPixelSize = -($bottom - $top) / $args{YDIM};
> makeWldFile( DEST_FILE => $wldFile,
> X_PIXEL_SIZE => $xPixelSize,
> Y_PIXEL_SIZE => $yPixelSize,
> X_ROT => 0,
> Y_ROT => 0,
> LEFT => $left,
> TOP => $top );
> if ( $verbose )
> print STDERR "World file created: $wldFile $xPixelSize, $yPixelSize, 0, 0, $left, $top\n";
> sub makeWldFile
> my %args =
> DEST_FILE => 'testOutput.wld',
> X_PIXEL_SIZE => 0.033333333,
> Y_PIXEL_SIZE => -0.033333333,
> X_ROT => 0,
> Y_ROT => 0,
> LEFT => -118.236313,
> TOP => 34.049172,
> @_,
> open ( OUT, ">$args{DEST_FILE}" ) || croak "Could not create $args{DEST_FILE}";
> print OUT "$args{X_PIXEL_SIZE}\n";
> print OUT "$args{X_ROT}\n";
> print OUT "$args{Y_ROT}\n";
> print OUT "$args{Y_PIXEL_SIZE}\n";
> print OUT "$args{LEFT}\n";
> print OUT "$args{TOP}\n";
> close OUT;
