[mapserver-users] Edit database attribute
Puneet Kishor
pkishor at GeoAnalytics.com
Mon May 6 09:05:10 EDT 2002
I didn't respond further because Erwin wanted "other" suggestions ;-)
but, now I will chip in some... there are other compiler options besides
perl2exe, though that might be sufficient. I like indigostar... they
gave me a headache-free mod_perl, Apache, install for my Windoze box.
that said, I am confused about protecting the source code... the source
code runs on the server, so no one has access to it anyway. I mean, you
can't just give away server scripts to folks without expecting them to
have the server pieces (web server, scripting engine, db drivers, et al)
in place.
I think Erwin is specifically interested in some, packageable binary
that he can give away to others, and not in a client/server solution.
Right Erwin?
pk/
On Monday, May 6, 2002, at 08:00 AM, Lowell Filak wrote:
> If my take on your reply is correct, you would like to protect your
> source code.? Have you checked into Perl2Exe by www.indigostar.com?
> I've never used it but if it works then that problem is solved. They
> have a free trial version available (I see from their ad).
> Lowell F.
> The following message was sent by "E Perik" <erwin at perik.nu> on Sun, 5
> May 2002 16:18:41 +0200.
>> Thanks Puneet and Steffen,
>> as you both state 'standard' mapserver + mapscript could easily do the
>> trick. 'Problem' in this case is, if someone else needs to edit the
>> data
>> the have the complete 'source' in their hands. If this could be
>> 'secured' or 'encrypted' I would be helped out at first, but no clue as
>> how to do that.
