[mapserver-users] Java Mapscript
    Andreas Hirner
    andreas_hirner at hotmail.com
    Mon May  6 10:21:39 PDT 2002
Hello Sathis,
once again thanks for help. All the files compiled without any problems, but
when I tried to implement a sample I ran into some general problems.
>In tomcat, I added the following line in /etc/tomcat4/conf/tomcat4.conf
>export LD_LIBRARY_PATH=/opt/mapserver/mapscript/java:$LD_LIBRARY_PATH
This is a problem, because I can't find a tomcat*.conf file in /etc. I
always thought tomcat is configured via the server.xml and web.xml files. Am
I wrong, and do I have to change the configuration.
I also have a general problem. Where do I have to store the mapserv
executable and the libmapscript.so library. Did you put both of them into
/opt/mapserver or in certain subdirectories.
The same thing goes for the java *.class files. Did you put them in the
/opt/mapserver/mapscript/java directory? Would it not be a good idea to put
them into WEB-INF directory.
It would be great if somebody could tell how the different components
interact and how to organize my application.
Thanks in advance
Andreas
_________________________________________________________________
Join the worlds largest e-mail service with MSN Hotmail.
http://www.hotmail.com
More information about the MapServer-users
