[mapserver-users] Re: Java Mapscript
    Sathiskumar Govindasamy
    gsathis at hashprompt.com
    Mon May  6 13:42:57 PDT 2002
Andreas,
I did an rpm install of tomcat4 and it did put a
/etc/tomcat4/conf/tomcat4.conf. If you have done other type of
installation, it might be somewhere else. Actaully that is the file
where you configure the JAVA_HOME variable.
server.xml is more of context setting and web.xlm is more of webapp
settings. tomcat4.conf takes care more of enviroment under which tomcat
is started.
As far as I understood, libmapscript.so and one another .so file is all
it matters if you want to use java mapscript. It has everything needed
within itself. I don't thing, where the mapserver is at, matters. You
just send the path where libmapscript.so is to tomcat.
Then you create a webapp and deploy it using tomcat manager. you can put
the mapscript class files at WEB-INF/lib directory if you have them in a
jar file or put them in WEB-INF/class/mapscript otherwise for a webapp.
Sathis
Andreas Hirner wrote:
> Hello Sathis,
> once again thanks for help. All the files compiled without any
> problems, but when I tried to implement a sample I ran into some
> general problems.
>> In tomcat, I added the following line in /etc/tomcat4/conf/tomcat4.conf
>> export LD_LIBRARY_PATH=/opt/mapserver/mapscript/java:$LD_LIBRARY_PATH
> This is a problem, because I can't find a tomcat*.conf file in /etc. I
> always thought tomcat is configured via the server.xml and web.xml
> files. Am I wrong, and do I have to change the configuration.
> I also have a general problem. Where do I have to store the mapserv
> executable and the libmapscript.so library. Did you put both of them
> into /opt/mapserver or in certain subdirectories.
> The same thing goes for the java *.class files. Did you put them in
> the /opt/mapserver/mapscript/java directory? Would it not be a good
> idea to put them into WEB-INF directory.
> It would be great if somebody could tell how the different components
> interact and how to organize my application.
> Thanks in advance
> Andreas
> _________________________________________________________________
> Join the world's largest e-mail service with MSN Hotmail.
> http://www.hotmail.com
More information about the MapServer-users
