[mapserver-users] bug (memory leak?)
Daniel Morissette
morissette at dmsolutions.ca
Mon May 6 13:42:23 EDT 2002
> jason wrote:
> Hi All,
> I am using the MapServer 3.5.1 on Win2000 as WMS server. I config the
> mapfile to use mapinfo .TAB data via OGR. The "GetMap" works fine with
> the scales less than 1:500,000 (say, 1:1000,000). But it fails for
> scales bigger than 1:500,000 (say 1:300,000) . It will use up all
> system memory (up to 2GB) and then fail. It seems that there is a
> memory leaking problem. Does anyone have similar problem or know how
> to fix it?
Jason,
A similar problem has been fixed in the TAB driver in OGR not long ago
(an infinite loop combined with a memory leak). I think you should try
again with a mapserv.exe built with the latest version of GDAL/OGR from
CVS.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
