[mapserver-users] Edit database attribute
    Juan S. Barros J.
    georef at tie.cl
    Mon May  6 19:32:56 PDT 2002
Erwin
If possible i will like to ask a couple of things a bit out of mapserver
programing but into its capabilities regarding the proyect where i am
working.
1.- in which movil / wireless plataform are you mounting your viever/editor?
or will and assembly with mapserver run on a Palm?
2.- will it run with a gps module (like center on where I am/gps)
3.- how do you plan to manage multiple users observing/editing the same
object?
4.- Are you planning to develop any internet I/O wireless conection with a
map server or the data will stay in the movil unit?
Juanse
Temuko-Chile
----- Original Message -----
To: 'Puneet Kishor' <pkishor at GeoAnalytics.com>; 'Steffen Macke'
<Steffen_Macke at dorsch.com.jo>; 'Lowell Filak' <lfilak at medinaco.org>; 'Paul
Spencer' <pagameba at magma.ca>; 'Hankley, Chip' <Chip.Hankley at GASAI.Com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, May 06, 2002 3:09 PM
Subject: RE: [mapserver-users] Edit database attribute
> Hi Puneet and others,
> Thanks for the input, and yes you are right Puneet that it's not a
> client/server solution I am looking for and also that I was hoping some
> other suggestions ;-)
> It's not that that I don't trust others ;-), but I don't see Microsoft
> as Open Source shipper either.
> I am a true believer in Open Source, but giving it all away is like
> letting the competition.....
> Lowell's suggestion of perl2exe is I nice one. My code is mostly
> mapscript, so I can see an advantage in that. Using PHP at the moment,
> but theoretically all could be changed to Perl.
> The basic idea of the Viewer/Editor is to show a simple map with
> streets, houses and for instance tree's. Zooming and selecting a tree to
> edit it's value's is the only functionality it should need. It will be
> used by someone from another company to edit the tree's attributes in
> the field.
> Besides ESRI's MapObjects there is also GeoObjects from BlueMarbleGeo.
> Did not see any comments regarding editing attributes, so sent them a
> mail regarding that just now. MapObjects should be possible to do it,
> but I did not see it being mentioned in any tutorial or help-file (yet).
> The advantage of MapObjects and GeoObjects is that a program does not
> need a webserver and scripting language's. Mapserver and mapscript are
> capable of doing just what I intend to do and have that working fine,
> but am looking for a single-application solution.
> Thanks,
> Erwin
> -----Original Message-----
> From: Puneet Kishor [mailto:pkishor at geoanalytics.com]
> Sent: Monday, May 06, 2002 3:05 PM
> To: Lowell Filak; E Perik; Steffen Macke
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] Edit database attribute
> I didn't respond further because Erwin wanted "other" suggestions ;-)
> but, now I will chip in some... there are other compiler options besides
> perl2exe, though that might be sufficient. I like indigostar... they
> gave me a headache-free mod_perl, Apache, install for my Windoze box.
> that said, I am confused about protecting the source code... the source
> code runs on the server, so no one has access to it anyway. I mean, you
> can't just give away server scripts to folks without expecting them to
> have the server pieces (web server, scripting engine, db drivers, et al)
> in place.
> I think Erwin is specifically interested in some, packageable binary
> that he can give away to others, and not in a client/server solution.
> Right Erwin?
> pk/
> On Monday, May 6, 2002, at 08:00  AM, Lowell Filak wrote:
> > If my take on your reply is correct, you would like to protect your
> > source code.? Have you checked into Perl2Exe by www.indigostar.com?
> > I've never used it but if it works then that problem is solved. They
> > have a free trial version available (I see from their ad).
> > Lowell F.
> > The following message was sent by "E Perik" <erwin at perik.nu> on Sun, 5
> > May 2002 16:18:41 +0200.
> >> Thanks Puneet and Steffen,
> >> as you both state 'standard' mapserver + mapscript could easily do
> the
> >> trick. 'Problem' in this case is, if someone else needs to edit the
> >> data
> >> the have the complete 'source' in their hands. If this could be
> >> 'secured' or 'encrypted' I would be helped out at first, but no clue
> as
> >> how to do that.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.351 / Virus Database: 197 - Release Date: 19/04/02
More information about the MapServer-users
