[mapserver-users] Font support in php_mapscript + mapserver
Gleydson Mazioli da Silva
gleydson.mazioli at ima.sp.gov.br
Tue May 7 15:56:10 EDT 2002
Hi all,
I'm trying to add the php_mapscript extensions support to mapserver, and when I try to run the
gmap application, I got the following error message:
"Warning: MapServer Error in msGetLabelSize(): Could not find/open font in /var/www/gmap/htdocs/gmap75.php3 on line 530"
The program phpinfo_mapscript.phtml, returns the following about php_mapscript support:
"MapScript Version ($Revision: 1.106 $ $Date: 2002/05/06 13:06:16 $)
MapServer version 3.6 (development) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE"
My compilation options are the following:
mapserver (lastest CVS repository)
--with-gd=static,../gd-1.8.4 --with-proj=/usr --with-ogr=../gdal-1.1.7/ogr --with-gdal=../gdal-1.1.7/apps/gdal-config
--with-wmsclient --with-php=/usr/src/geop/php4-4.0.6 --with-freetype=/usr
gd 1.8.4
./configure --enable-freetype2=/usr
php 4.0.6
--with-calendar --without-ttf --with-t1lib=shared,/usr --enable-memory-limit --enable-sysvsem --enable-sysvshm
--enable-track-vars --enable-trans-sid --enable-bcmath --with-bz2 --enable-ctype --with-db2 --with-iconv --with-ndbm
--enable-exif --enable-filepro --enable-ftp --with-gettext --enable-mbstring -with-pcre-regex=/usr --enable-shmop
--enable-sockets --with-xml=/usr --with-expat-dir=/usr --enable-yp --with-zlib --prefix=/usr --with-regex=system
--disable-rpath --disable-static --with-layout=GNU --with-zlib-dir=/usr --with-jpeg-dir=shared,/usr --with-xpm-dir=shared,/usr/X11R6 --with-png-dir=shared,/usr --with-freetype-dir= --enable-xslt --with-xslt-sablot=shared,/usr
Related with gd, I've added the flag -DHAVE_LIBFREETYPE and -I include options in Makefile to get it compiled on
Debian.
I've tried many ways to solve that, but from this point without luck.
Thanks in advanced
gleydson at debian.org
gleydson at cipsga.org.br
