[mapserver-users] County Projection Help
Hankley, Chip
Chip.Hankley at GASAI.Com
Fri May 10 09:55:50 EDT 2002
I'm having trouble writing the PROJ4 definition for the following
projection:
Spatial_Reference_Information:
Horizontal_Coordinate_System_Definition:
Planar:
Map_Projection:
Map_Projection_Name: Lambert Conformal Conic
Lambert_Conformal_Conic:
Standard_Parallel: 45.056389
Standard_Parallel: 44.745278
Longitude_of_Central_Meridian: -89.770000
Latitude_of_Projection_Origin: 44.405556
False_Easting: 245000
False_Northing: 0
Planar_Coordinate_Information:
Planar_Coordinate_Encoding_Method:
Coordinate_Representation:
Abscissa_Resolution:
Ordinate_Resolution:
Planar_Distance_Units: survey feet
Geodetic_Model:
Horizontal_Datum_Name: North American Datum of 1983 (1991 adjusted)
Ellipsoid_Name: Geodetic Reference System 1980 (GRS 80)
Semi-major_Axis: 20923797.3851
Denominator_of_Flattening_Ratio: 298.274225
This is what I've come up with, but it doesn't seem to be working:
PROJECTION
"proj=lcc"
"lat_1=45.056389"
"lat_2=44.745278"
"lat_0=44.405556"
"lon_0=-89.770000"
"x_0=245000"
"y_0=0"
"ellps=GRS80"
"datum=NAD83" #Tried w/ and w/out this line
"to_meter=0.3048006096"
"no_defs"
END
What am I missing. Is there some special way to define the NAD83(91) Datum?
TIA!
Chip Hankley
