[mapserver-users] 3.6 (development)
imap at chesapeake.net
Fri May 10 13:44:03 EDT 2002
Daniel,
This bit about getting errors on ANTIALIAS TRUE/FALSE
was a case of user error. one of those emails I wish
I could have taken back 10 minutes after I sent it...
After seeing your email about the stability of 3.6
in the CVS... Im going to back off to the
20020430 version..
I had been trying to get the 3.6 CVS version working
last night and was curious to see these:
msSaveImage(img,filename,transparent,interlace,quality);
[ returns int ]
msSaveImageGD(img,filename,type,transparent,interlace,quality);
[ returns int ]
messed with these for a couple of hours, but never could
get them to work... it was complaining about wanting
gdImagePtr in arg 1 (just FYI). I didnt have much luck
getting to render with perl mapscript.
Regards,
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc.
Daniel Morissette wrote:
> imap at chesapeake.net wrote:
> > OK, I am getting ate up here with 3.6 from the CVS
> > I may have missed previous posts about mapfile changes, but
> > so far I have snagged on ANTIALIAS TRUE, FILLED TRUE and
> > LABEL font SIZE xxx Can someone give a rundown on the mapfile
> > parameter changes for 3.6? Did we get rid of TRUE/FALSE
> > again in the new version? Not sure whats up with Label
> > font SIZE, maybe a param name change or something???
> I'm not aware of any further change with respect to TRUE/FALSE. And I
> don't remember any change with respect to label size either.
> Maybe if you send the exact error message that you get and the
> corresponding mapfile section then we may be able to give more hints.
> Note that due to the way the parser works, sometimes the actual error in
> the mapfile is on the line that precedes the line where the error is
> reported. So in your case if you get an error about the "SIZE" keyword
> then I suggest that you look at what came before the SIZE in your
> mapfile.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
