[mapserver-users] Return mapxy
Puneet Kishor
pkishor at GeoAnalytics.com
Fri May 10 17:11:44 EDT 2002
well, you will have to submit a form in order to send it to the server.
which will cause redrawing. what you can do is to remake the same map as
before.
if you are really against redrawing at all, you can achieve the effect by
using frames. use a hidden frame to submit the form with your mouseclick
values and stuff in the database.
hth,
pk/
> -----Original Message-----
> From: Van Ulden, Joost [mailto:jvanulde at NRCan.gc.ca]
> Sent: Friday, May 10, 2002 2:54 PM
> To: Mapserver-Users at Lists. Gis. Umn. Edu (E-mail)
> Subject: [mapserver-users] Return mapxy
> Is it possible to return only the xy coordinates of a user
> click without
> redrawing the map? We would like to return the xy
> coordinates and insert
> them into a database. We can do this already, but with a
> combination of
> zoom and javascript.
> Any suggestions would be helpful.
> Joost van Ulden
> Data Integration Specialist
> GSC-Pacific Division
> 101-605 Robson St.
> Vancouver, BC V6B 5J3
> 604.666.7525
> jvanulde at nrcan.gc.ca
