[mapserver-users] display UTM points on Lambert data?
Dylan Keon
keon at nacse.org
Tue May 14 18:09:19 EDT 2002
For the archives...
Steve Lime confirmed that it's best to just define a projection object for
the dynamically generated layer of UTM-based points, transforming it to
Lambert CC on the fly (thanks Steve).
Here are the PROJ4 parameters for my map object...
PROJECTION
"proj=lcc" # Lambert Conformal Conic
"datum=NAD83" # North American Datum of 1983
"units=ft" # international feet (0.3048 meters)
"lon_0=-120.5" # central meridian
"lat_0=41.75" # latitude of projection's origin
"lat_1=43" # 1st standard parallel
"lat_2=45.5" # 2nd standard parallel
"x_0=400000" # false easting (meters), (1,312,335.958 ft)
"y_0=0" # false northing (meters)
END
...and for my layer object...
PROJECTION
"proj=utm"
"ellps=clrk66"
"zone=10"
"north"
END
In testing with a static shapefile (UTM zone 10), this works really well :-)
--Dylan
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, May 13, 2002 6:13 PM
Subject: [mapserver-users] display UTM points on Lambert data?
> I'm working with statewide data sets for Oregon. Since Oregon spans two
UTM
> zones, I projected my UTM10 and UTM11 data to a common projection (Oregon
> centered Lambert, a version of Lambert CC). All the layers match up
nicely
> in my MapServer app.
> Next, I'd like to display point layers that are dynamically generated from
> database queries. The coordinates in the database are in UTM. Oregon
> Lambert units are international feet. It's easy enough to convert meters
to
> international feet, but the layers still won't match up since the features
> are in different projections.
> Do I need to reproject the dynamically generated point layer on the fly?
Is
> there a better solution that I'm not seeing? I'm sure others have dealt
> with the issue of spanning two (or more) UTM zones, and displaying points
> from different projections...
> Thanks.
> --Dylan
