[mapserver-users] MapServer 3.5 & Postgis
lists
lists at mail.office.webstar.co.uk
Wed May 15 10:13:52 EDT 2002
Hi
I'm a newbie with GIS, so please have patience :)
I have installed the PostGIS 0.7 extension with Postgresql 7.2 (RedHat
7.3), and PostGIS seems fine. I have managed to convert and input shp file
data.
I have also compiled mapserver 3.5 and the itasca demo works fine.
I compiled mapserver with this ./configure :
./configure --with-proj=/usr/local/lib --with-postgis=yes --with-wmsclient
I then wrote a simple map file for the data I had input into postgres.
This is the abandoned mine land data from http://www.nationalatlas.gov/atlasftp.html
When reading directly from shp files, this .map file works :
NAME EX1
EXTENT -159.6 28.77 -71.4667 70.5
SIZE 400 300
SHAPEPATH "../data"
LAYER # start of the "mines" layer object
NAME "mines"
DATA abnminx020
STATUS DEFAULT
TYPE POINT
CLASS
COLOR 120 120 220
OUTLINECOLOR 10 10 0
END # end of class object
END # end of layer object
END # end of map file
However, if I add :
CONNECTIONTYPE local
into the LAYER section, I get this error :
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF">
getSymbol(): Symbol definition error. (local):(5)
</BODY></HTML>
If I change the map file to read from the database :
NAME EX2
SIZE 400 300
CONNECTIONTYPE postgis
NAME "mines"
CONNECTION "user=xxx password=xxx dbname=mines host=localhost port=5432"
DATA "the_geom from themines"
STATUS ON
TYPE POINT
CLASS
COLOR 120 120 220
then I get a plain white .png with no detail at all.
Any help would be much appreciated - I'm rather stumped at the moment !
Regards and thanks in advance
Arif Saleem
