[mapserver-users] Problem : decimal point in dbf / itemquery ?
Robert Fritz
robert-fritz at web.de
Thu May 16 01:17:17 PDT 2002
Hello,
i use itemquery to search an entry in a shapefile. the column is formated as
Number with a ",".
the query results in "msQueryByAttributes(): Search returned no results. No
matching record(s) found. "
Filter:
Filter ("[X_COORD]" = "%x%") (it works if I query other columns)
Link:
/cgi-bin/mapserv35?x=2536537,81331&mode=itemquery&.....
Is the "," a problem or is there another Error?
Thank you for help,
Robert
More information about the MapServer-users
