[mapserver-users] Problem : decimal point in dbf / itemquery ?
Lowell Filak
lfilak at medinaco.org
Thu May 16 09:15:43 EDT 2002
I think you may want to remove the "". Numbers are queried without "" whereas characters are queried with "".
Lowell F.
The following message was sent by "Robert Fritz" <robert-fritz at web.de> on Thu, 16 May 2002 10:17:17 +0200.
> Hello,
> i use itemquery to search an entry in a shapefile. the column is formated as
> Number with a ",".
> the query results in "msQueryByAttributes(): Search returned no results. No
> matching record(s) found. "
> Filter:
> Filter ("[X_COORD]" = "%x%") (it works if I query other columns)
> Link:
> /cgi-bin/mapserv35?x=2536537,81331&mode=itemquery&.....
> Is the "," a problem or is there another Error?
> Thank you for help,
> Robert
