[mapserver-users] build error with GDALGetRasterYSize in php_mapscript.so
Ellis Robin (Bundaberg)
Robin.Ellis at nrm.qld.gov.au
Tue May 21 01:46:31 EDT 2002
In the process of trying to build mapserver 3.6 with PHP 4.2.0 I have
ended up including several different components in the build. When
running make after this configuration:
./configure --with-php=/data4/userdata/rob/php-4.2.0
--with-apxs=/usr/local/apache/bin/apxs
--with-tiff=/data4/userdata/rob/v3.5/tiff-v3.5.7/libtiff
--with-gd=/data4/userdata/rob/v3.5/gd-1.8.4
--with-jpeg=/data4/userdata/rob/v3.5/jpeg-6b
--with-postgis=/usr/local/pgsql/bin/pg_config
--with-gdal=/data4/userdata/rob/gdal-1.1.6/apps/gdal-config
--with-ogr=/data4/userdata/rob/gdal-1.1.6/ogr --with-proj=/usr/local
--with-epp
I get this error in the GDALGetRasterYSize component of the build:
GDALGetGeoTransform 0xcc4
/data4/userdata/rob/v3.6b/mapserver-3.6.0-beta1/libmap.a(mapresample.o)
TIFFSwabArrayOfDouble 0x13f0
/data4/userdata/rob/v3.6b/mapserver-3.6.0-beta1/libmap.a(mapraster.o)
TIFFSwabArrayOfDouble 0x142c
init_destination 0xacc
/usr/local/lib/libgd.a(gd_jpeg.o)
init_destination 0xad0
clrget 0x3354
clrget 0x33c0
gdPutC 0x8
/usr/local/lib/libgd.a(gd_wbmp.o)
GDALGetRasterColorTable 0xa18
GDALGetRasterColorTable 0xad0
.rem 0x1b74
.rem 0x1c20
.rem 0x1ce8
.rem 0xc04
/usr/local/lib/libgd.a(gd.o)
.rem 0xd64
.rem 0xd78
.rem 0x16bc
.rem 0x16ec
.rem 0x1968
.rem 0x197c
GDALRasterIO 0xd0c
GDALRasterIO 0xdec
GDALRasterIO 0xe3c
GDALRasterIO 0xea0
GDALGetRasterYSize 0x578
GDALGetRasterYSize 0x8a4
GDALGetRasterYSize 0x8dc
GDALGetRasterYSize 0xd10
ld: fatal: relocations remain against allocatable but non-writable
sections
collect2: ld returned 1 exit status
make[1]: *** [php_mapscript.so] Error 1
make[1]: Leaving directory
`/data4/userdata/rob/v3.6b/mapserver-3.6.0-beta1/mapscript/php3'
Has anybody overcome similar problems to this in the past?
Thanks very much
Rob
Robin Ellis
Department of Natural Resources and Mines
PO Box 1167
Bundaberg QLD 4670
+61 7 4131 5771
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
