[mapserver-users] XML mapfile?
Puneet Kishor
pkishor at GeoAnalytics.com
Wed May 22 12:26:36 EDT 2002
well, I did mention it below... ;-). Yup, validating against a DTD would
be useful.
pk/
On Wednesday, May 22, 2002, at 11:15 AM, C F wrote:
> On top of the things I mentioned, the other "cool" thing I forgot to
> mention is, validation. You veterans probably don't have this
> problem... but being a new MapServer prospect, I've had some real
> problems tracking down my mapfile errors. Writing an XML schema that
> defines all the rules for the mapfile format is pretty straightforward
> and XML parsers are generally good at telling exactly what rule has
> been broken and where.
>> However, in the spirit of discussion, there is one area where XML
>> might be helpful. Most code editors (Homesite, jEdit, Pepper) nowadays
>> can parse XML to create an XML tree. This can make editing a complex
>> Mapfile easier as one can check for node closures, correctness and
>> completeness.
