[mapserver-users] XML mapfile?
Tom.Kralidis at ccrs.nrcan.gc.ca
Wed May 22 13:37:44 EDT 2002
All,
I think the group should think about an XML conversion a bit. Functionality
and efficiency are important to consider before chasing down the latest XML
technologies. If creating a mapfile becomes more difficult as a result of
XML, this may deter some.
..Tom
> -----Original Message-----
> From: Mike Haarman [mailto:mhaarma at socsci.umn.edu]
> Sent: Wednesday, May 22, 2002 12:49 PM
> To: C F
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] XML mapfile?
> CF,
> You are not alone. I've had similar discussions off-list
> with Steve and
> Daniel. There is no consensus yet, but developments at OGC point in
> this direction also. This is neither here nor there, but I
> would like to
> address the two concerns raised here.
> Performance. I really feel this is a non-starter. Your
> solution is one
> method and there are others for optimization of XML parsing. Its not
> trivial work, but it is perfectly feasible.
> Editing. XML is self-documenting, human-readable, plain-text
> as we all
> know. Where is the difficulty?
> Your points about generation and transformation are right on,
> particularly in light of the opportunities for integration with other
> publishing or content delivery environments.
> Mike
> On Wed, 22 May 2002, C F wrote:
> > I hear you on the performance concerns. However, I think
> we could get
> > around that by serializing the XML DOM object into a file
> (that's how ArcIMS
> > does it.... which probably hurts my case more than
> anything). Then the only
> > time the XML file would be parsed is in the first request
> after a change to
> > it is made (done by using file's timestamps). Who knows,
> it might even be
> > fast than the current implementation. I don't really know
> if that's true as
> > I have not actually used serialized DOM files in my own
> apps... but it makes
> > sense to me that it could possibly alleviate your
> > Now, assuming that performance wasn't an issue, I still
> hear concerns about
> > simplicity. In raw text-edit mode, there's nothing that
> can be done about
> > that. I consider it a very minor difference... but that's
> just a matter of
> > taste and there will never be a consensus on that. All I
> can say about that
> > is that XML would make it tremendously easier for people to
> write mapfile
> > generation/editing tools.... also for people writing tools
> to batch update
> > their mapfiles, etc. In other words, with maybe the very
> minor exception of
> > manual text editing, it would make them much easier to
> handle.... again a
> > maybe matter of taste :)
> > MapScript is a solution... but may not be a solution for
> everyone if they
> > want to build a more of a single, cross-platform solution
> with minimum
> > modification and customization to the servers involved.
> Also, the fact that
> > we'd gain access to this important mapfile information
> without the need for
> > "programming" would be nice. I envision this would be set
> up in much the
> > same way it is now, only with XSLT templates replacing the
> current form of
> > templates.
> > Well those are my thoughts.... but I haven't really
> received any positive
> > feedback since my original post so it looks I'm all alone
> :) People seem to
> > be comfortable with the current format. Or maybe I'm just
> looking at it for
> > use in different uses than it has traditionally been used
> for. I think
> > everybody that's worked on it has done an *awesome* job. I
> think the
> > product is great, just call me a whiner if you'd like :)
> Paul Ramsey's idea
> > of out we could have it both ways is something I might do
> for myself anyway.
> > If there is ever enough interest in it maybe that's
> somewhere I can
> > contribute to the project.
> > >From: Daniel Morissette <morissette at dmsolutions.ca>
> > >To: C F <gis_consultant at hotmail.com>
> > >CC: mapserver-users at lists.gis.umn.edu
> > >Date: Wed, 22 May 2002 08:19:31 -0400
> > >I think that Steve has been considering a switch to XML
> eventually, but
> > >I don't think there is any formal plan.
> > >I agree that XML might give more flexibility to the user
> by allowing him
> > >to read the mapfile from external tools, but it would be
> at the cost of
> > >performance (i.e. speed) when parsing the mapfile for
> every request.
> > >Combine this loss of performance with the fact that XML
> would be harder
> > >to edit manually than the current format, and you know
> where I stand
> > >personally.
> > >I'm not saying that if we were redesigning from scratch I wouldn't
> > >consider XML (we use it a lot in other apps), but since
> we've already
> > >got a very good (fast and simple) mapfile format then I
> won't be the one
> > >initiating a switch to XML mapfiles.
> > >Note that MapScript already gives you access to almost
> every piece of
> > >information from the mapfile, so when the CGI cannot do
> what you need
> > >then the logic path is to switch to MapScript, and then sky is the
> > >limit.
> > >My 0.02$
> > > Daniel Morissette morissette at dmsolutions.ca
> > > DM Solutions Group http://www.dmsolutions.ca/
> > > Don't put for tomorrow what you can do today, because if
> > > you enjoy it today you can do it again tomorrow.
> > _________________________________________________________________
> > MSN Photos is the easiest way to share and print your photos:
> > http://photos.msn.com/support/worldwide.aspx
> Mike Haarman Minnesota Population Center,
> mhaarma at socsci.umn.edu University of Minnesota,
> 537 Heller Hall,
> Minneapolis, MN 55455
> Co-Architect, Programmer,
> National Historical GIS -- http://www.nhgis.org/
> Maintainer,
> DDI Codebook DTD -- http://www.icpsr.umich.edu/DDI/
