[mapserver-users] XML mapfile?
Jean-Francois.Doyon at ccrs.nrcan.gc.ca
Wed May 22 15:37:28 EDT 2002
Allright,
I'm gonna go against the flow and say I WOULD like an XML mapfile, or at
least having the option :)
The big thing in my case for me is interoperability, if you use a standard
way to structure the mapfile, then other tools can more easily read and
write this mapfile, which is something I've run into more than once as a
problem. Notably I sometimes want to apply a batch change to hundreds of
mapfiles, and right now that's not as easy as it would be if they were XML
(I'd have to write my own MapFile parser and so on).
Basically there's lots of tools that work great with XML, but not too many
that understand MapFiles :)
I suppose editing one in XML might be harder on the eye ... Personally I use
XML tools (Such as XML Spy), which allows me to do it naturally and
graphically.
Personally I'd be willing to live with having to edit an XML file manually
given the benefits ... But then I stare at XML quite a bit, maybe more than
average :)
Daniel, wouldn't things like MapEdit benefit from this ? Of course now it's
too late as it is written, but seems to me having an app read/write XML is
easier than for a custom file format.
Validation could be very handy too, hunting down errors in a mapfile might
be made easier ?
As for the performance, I don't know ... I allways imagined MapServer
linking to expat for instance to read it's XML MapFile, and from my
experience anyway, Expat is pretty darn fast. But I really don't know how it
might compare to the current setup, and I've never done any benchmarking!
Also, having an XML MapFile option alone might foster/stimulate the
development of more MapServer related tools ? I also wonder how this might
cooperate with OGC type things like GML, FGDC Metadata, etc ... I could
imagine embeding a given XML Structure (Say FGDC XML) INTO a mapfile for
example!
So many possibilities!
My .02$
J.F.
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Wednesday, May 22, 2002 2:32 PM
To: morissette at dmsolutions.ca; gis_consultant at hotmail.com
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] XML mapfile?
Ok, you're a whiner. <g>
This is being looked into. There are other competing priorities at the
moment so it's down
the list a bit right now. My plan would be to support both native and
XML-based configuration
in the short term until some of the performance issues could be dealt
with. One could actually
make MapServer read XML with just a few tweaks of the lexer, and since
you wouldn't validate
at that point anyway...
I'd like to see the conversation continue, perhaps off list with a
smaller group. Some practical
demonstrations of the benefits of an XML-based config file might also
help those of us not
experienced with XML see the light.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "C F" <gis_consultant at hotmail.com> 05/22/02 10:51AM >>>
I hear you on the performance concerns. However, I think we could get
around that by serializing the XML DOM object into a file (that's how
ArcIMS
does it.... which probably hurts my case more than anything). Then the
only
time the XML file would be parsed is in the first request after a
change to
it is made (done by using file's timestamps). Who knows, it might even
be
fast than the current implementation. I don't really know if that's
true as
I have not actually used serialized DOM files in my own apps... but it
makes
sense to me that it could possibly alleviate your performance
concerns.
Now, assuming that performance wasn't an issue, I still hear concerns
about
simplicity. In raw text-edit mode, there's nothing that can be done
about
that. I consider it a very minor difference... but that's just a
matter of
taste and there will never be a consensus on that. All I can say about
that
is that XML would make it tremendously easier for people to write
mapfile
generation/editing tools.... also for people writing tools to batch
update
their mapfiles, etc. In other words, with maybe the very minor
exception of
manual text editing, it would make them much easier to handle.... again
a
maybe matter of taste :)
MapScript is a solution... but may not be a solution for everyone if
they
want to build a more of a single, cross-platform solution with minimum
modification and customization to the servers involved. Also, the fact
that
we'd gain access to this important mapfile information without the need
for
"programming" would be nice. I envision this would be set up in much
the
same way it is now, only with XSLT templates replacing the current form
of
templates.
Well those are my thoughts.... but I haven't really received any
positive
feedback since my original post so it looks I'm all alone :) People
seem to
be comfortable with the current format. Or maybe I'm just looking at
it for
use in different uses than it has traditionally been used for. I think
everybody that's worked on it has done an *awesome* job. I think the
product is great, just call me a whiner if you'd like :) Paul Ramsey's
idea
of out we could have it both ways is something I might do for myself
anyway.
If there is ever enough interest in it maybe that's somewhere I can
contribute to the project.
>From: Daniel Morissette <morissette at dmsolutions.ca>
>To: C F <gis_consultant at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu
>Date: Wed, 22 May 2002 08:19:31 -0400
>I think that Steve has been considering a switch to XML eventually,
but
>I don't think there is any formal plan.
>I agree that XML might give more flexibility to the user by allowing
him
>to read the mapfile from external tools, but it would be at the cost
of
>performance (i.e. speed) when parsing the mapfile for every request.
>Combine this loss of performance with the fact that XML would be
harder
>to edit manually than the current format, and you know where I stand
>personally.
>I'm not saying that if we were redesigning from scratch I wouldn't
>consider XML (we use it a lot in other apps), but since we've already
>got a very good (fast and simple) mapfile format then I won't be the
one
>initiating a switch to XML mapfiles.
>Note that MapScript already gives you access to almost every piece of
>information from the mapfile, so when the CGI cannot do what you need
>then the logic path is to switch to MapScript, and then sky is the
>limit.
>My 0.02$
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
