[mapserver-users] no PNG file created
mastre
mastre at makina-corpus.com
Thu May 23 05:00:16 EDT 2002
The stand alone mapserver CGI seems to work fine.
Here a sample of my .map
Result with gif output and mapserver 3.5 can be seen here: http://maps.makina-corpus.com/localis/
$samplemap =<<<_END_
MAP
NAME AQUITAINE
STATUS ON
SIZE $resx $resy
EXTENT $extent
UNITS METERS
IMAGETYPE PNG
SHAPEPATH "$fpath/tmp/data"
IMAGECOLOR 255 255 255
interlace on
transparent off
# Start of web interface definition (including WMS enabling metadata)
WEB
TEMPLATE $fpath/src/txt.html
MINSCALE 150000
MAXSCALE 7950000
IMAGEPATH "$fpath/tmp/rendered/"
IMAGEURL "tmp/rendered/"
METADATA
WMS_TITLE "Makina Mapserver Test Zone"
WMS_ABSTRACT "Tests d'implementation de solution de generation dynamique de cartes."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE ""
WMS_SRS "EPSG:26915"
END
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 100 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT TRUE
STATUS TRUE
END
# Start of symbol definitions
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 2 2 END
FILLED false
STYLE 10 5 5 10 END
END
SYMBOL
NAME "img"
TYPE pixmap
IMAGE "$fpath/images/comp.png"
END
# Start of layer definitions
layer
name commune
type point
group fond
data "./$id"
classitem "NOM"
$alabels
status on
class
label
partials false
color 0 0 0
outlinecolor 255 255 255
antialias true
position auto
angle auto
force true
offset 0 -2
end
size 9
symbol img
end
END
layer
name PointOfInterest
type point
group fond
data "./$qid"
classitem "poi"
status $poistatus
class
symbol circle
outlinecolor 0 0 0
color 255 0 0
end
end
END
__END__
On Wed, 22 May 2002 14:14:34 -0500 (CDT)
Pushkar Pradhan <pushkar at ERC.MsState.Edu> wrote:
> Can you post your code, does the stand alone mapserver CGI appl. work?
> > Hi,
> > I've compiled mapserver with php mapscript support.
> > Mapserver -v :
> > MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> > make doesn't output any error.
> > Mapserver 3.5 works fine with the same data files and gif output.
> > No error in apache logs, but no image is created on the filesystem.
> > My gdlib version is 1.8.4 / 2.0.1 .
> > Thanks
> > mastre
> -Pushkar S. Pradhan
