[mapserver-users] no PNG file created
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Thu May 23 14:54:49 EDT 2002
Did you check your tmp/rendered dire. if the file is atleast created
there?
Most likely you need:
IMAGEURL "/tmp/rendered/" # "/" before tmp
> The stand alone mapserver CGI seems to work fine.
> Here a sample of my .map
> Result with gif output and mapserver 3.5 can be seen here: http://maps.makina-corpus.com/localis/
> $samplemap =<<<_END_
> MAP
> NAME AQUITAINE
> STATUS ON
> SIZE $resx $resy
> EXTENT $extent
> UNITS METERS
> IMAGETYPE PNG
> SHAPEPATH "$fpath/tmp/data"
> IMAGECOLOR 255 255 255
> interlace on
> transparent off
> # Start of web interface definition (including WMS enabling metadata)
> WEB
> TEMPLATE $fpath/src/txt.html
> MINSCALE 150000
> MAXSCALE 7950000
> IMAGEPATH "$fpath/tmp/rendered/"
> IMAGEURL "tmp/rendered/"
> METADATA
> WMS_TITLE "Makina Mapserver Test Zone"
> WMS_ABSTRACT "Tests d'implementation de solution de generation dynamique de cartes."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE ""
> WMS_SRS "EPSG:26915"
> END
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 255 255 255
> SIZE tiny
> END
> STYLE 1
> SIZE 100 2
> COLOR 255 255 255
> UNITS KILOMETERS
> INTERVALS 2
> TRANSPARENT TRUE
> STATUS TRUE
> END
> # Start of symbol definitions
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 2 2 END
> FILLED false
> STYLE 10 5 5 10 END
> END
> SYMBOL
> NAME "img"
> TYPE pixmap
> IMAGE "$fpath/images/comp.png"
> END
> # Start of layer definitions
> layer
> name commune
> type point
> group fond
> data "./$id"
> classitem "NOM"
> $alabels
> status on
> class
> label
> partials false
> color 0 0 0
> outlinecolor 255 255 255
> antialias true
> position auto
> angle auto
> force true
> offset 0 -2
> end
> size 9
> symbol img
> end
> END
> layer
> name PointOfInterest
> type point
> group fond
> data "./$qid"
> classitem "poi"
> status $poistatus
> class
> symbol circle
> outlinecolor 0 0 0
> color 255 0 0
> end
> end
> END
> __END__
> On Wed, 22 May 2002 14:14:34 -0500 (CDT)
> Pushkar Pradhan <pushkar at ERC.MsState.Edu> wrote:
> > Can you post your code, does the stand alone mapserver CGI appl. work?
> > > Hi,
> > > I've compiled mapserver with php mapscript support.
> > > Mapserver -v :
> > > MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> > > make doesn't output any error.
> > > Mapserver 3.5 works fine with the same data files and gif output.
> > > No error in apache logs, but no image is created on the filesystem.
> > > My gdlib version is 1.8.4 / 2.0.1 .
> > > Thanks
> > > mastre
> > -Pushkar S. Pradhan
-Pushkar S. Pradhan
