[mapserver-users] XML mapfile?
Steve Lime
steve.lime at dnr.state.mn.us
Thu May 23 14:22:55 EDT 2002
This ones not all that difficult. MapServer can already to GML output
for WMS queries, and making the main CGI application support this as an
option is high on my to-do list. Just waiting for some of the other
vector output handling to stabilize first. You can write XML templates,
only problem is that the mime-type is wrong, although that could be
fixed easily too.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Ryan, Adam" <ARyan at co.linn.or.us> 05/23/02 11:49AM >>>
This seems like the way of the future.
I'm new at this but here's an idea: Have mapserver create an xml
document in
response to a query. This would allow more dynamic manipulation of
query
results.
Adam Ryan
Linn County
-----Original Message-----
Sent: Wednesday, May 22, 2002 1:45 PM
To: mapserver-users at lists.gis.umn.edu
Cc: Daniel Morissette; Puneet Kishor
Subject: Re: [mapserver-users] XML mapfile?
Hi All!
WARNING -- I'm a now-former Lurker with a longwinded set of ideas and
commentary. If you've thought of this before and it can't be done,
please
tell me why... Here goes! THANKS for mapserv!
I've read the comments about XML mapfiles, with relish, and I have
some
reasons why I think it must be done (not should, must).
1) XML is not _that_ slow, if you use a good parser. Furthermore, you
can
(and should) serialize the DOM once and then re-load the serialized
object,
as someone mentioned earlier.
2) It's easy to "manufacture" XML programmatically by user programs
that
might automate the production of sites (because there are dozens of
existing
libraries that facilitate creation of XML from data).
3) It sure would be nice to have a "map on demand" server (perhaps a
web
service using XML-RPC or SOAP?) that allows you to fire a well-formed
XML
"mapfile" to the server and receive an image or HTML page in response.
4) Although (4) can be done in mapscript, why bother if an XML mapfile
can
do it? You can document what's on the server (or have the web service
provide XML for the "default" DOM tree for mark-up; woooo, neato) and
folks
can use ANYTHING to edit / generate the XML. I can imagine a
client-side
app in, e.g., python, that gets the XML, marks up the DOM tree, makes
a
server request to retrieve the rendered maps, then draws additional
(locally-stored) data on top. One could even make a client-side
drawing
library that does coordinate conversions and the like (hey -- how
about
mapscript?).
5) EVERYBODY knows how to write and validate XML already. This one
feature
makes me want to switch right now. The only 'lint' we have for
mapfiles is
mapserv itself. It's a PAIN to edit the mapfile and hit the browser
to
check for errors (for one thing, you need a separate development web
server,
and that introduces hassles with user permissions). If we have an XML
mapfile and a proper DTD, a validating parser will automatically find
poorly-formed XML and missing delimiters and flag them (imagine not
having
to find the missing 'END' in a 2000-line mapfile). Furthermore,
'maplint'
could take big-time advantage of the XML for system management. I
envision
a python script that loads the XML mapfile, then traverses the LAYER,
CLASS,
and LABEL definitions and reports whether there are missing files,
attributes in the CLASSITEM or LABELITEM specifications that aren't in
the
DBF files, etc...
5a) Wow! 'maplint' could even load the XML mapfile for, e.g. version
4.0
mapserv and convert it to a version 4.1 XML mapfile!
5b) Inheritance. You can define "new" versions by subclassing the
old
versions. If it's properly implemented in mapserv, a future mapserv
4.0
could read, e.g. 4.1 XML mapfiles and SKIP over the DOM nodes for the
4.1
features that it doesn't support... Or 4.1 could "skip and warn"
(instead
of failing), when an obsoleted 4.0 feature is encountered. It's easy,
because the code that processes the information in the DOM tree is
independent of the code that reads the DOM tree. Web browsers do it,
mapserv can too -- the XML reader uses the DTD to read and validate the
DOM
tree; what the code does with that DOM tree is up to the code...
Fatal
mapserv errors displayed on client terminals due to typos in
infrequently
used (and thus poorly tested) portions of mapfiles are bad medicine;
XML can
help to avoid them.
5c) Most editors are XML-aware and do stuff like syntax highlighting,
auto-inserting tags, and finding missing tags, angle brackets and the
like.
Who wants to maintain a "mapfile-mode" for emacs or vim?
6) How about using the XML mapfile to populate a DOM tree, then
programmatically (e.g. mapscript python or perl) build an image in a
non-web-based tool. WOW. A "poor man's ArcView" is only a few
hundred
lines of PyQT or PyGnome/PyGTK code away (or a thousand or so lines of
line
noise for Perl/QT or Perl/GTK programmers. Just kidding. Maybe.).
The
program could traverse the DOM tree that specifies the map structure
and
construct the whole GUI on the fly, creating GUI widgets that allow
layers
to be turned on/off, etc. And the same DOM tree makes the pictures!
Save
the DOM tree to an XML file, and *PRESTO* your view is on the web!
6a) Incidentally, one could document the options available for
mapserv
objects using another XML file (I'm not an XSL expert, but maybe that's
the
way?). Then the nifty mini-ArcView could build all the layer option
dialog
boxes on the fly, radio/checkbox arrays, label options, and the whole
garbanzo...
7) At some level, with appropriate editors, XML and DTD's are
self-documenting. This is a big winner, since one presumes that new
functionality is coming all the time. Properly designed, nearly all of
the
(6) and (6a) code could be independent of mapserv revisions; unless a
new
major option needs to be added, the GUI code should require few
revisions to
keep up with mapserv.
Although XML is not required to do any of these things, XML facilitates
the
incorporation of mapserver or mapscript or any number of future
children of
mapserv/mapscript into other software systems, with consistent
results.
Pardon me, but I'm thinking BIG -- mapserv is a powerful, flexible,
extensible, open, facility for rendering all kinds of geographic
information, FAST. It can be a component for larger software systems,
with
"not-too-much" effort. If all you're doing is blowing pictures into
web
browsers, forget XML. But for everything else, one doesn't want to
have to
write and maintain (a) a mapfile parser/generator of one's own, or (b)
a
mapscript application for every single part of my application.
I've done some fiddling with "XML mapfiles". I designed that work as
an
input vehicle for python/mapscript. It is a simple but tedious task
to
build a DTD for mapfiles, but I have no control over where mapserv
goes, so
I abandoned the effort for now. If you have an XML mapfile and python
with
mapscript, it should be possible (perhaps even simple but tedious) to
implement all of mapserv's functionality in an OO code that is easily
extended (by inheritance) for new applications, either on the web or
standalone. The resulting classes could be used as a starting point
for all
the stuff I outlined above. I'm way too busy to write it all myself,
but I
have a general design in place. This can probably all be done outside
of
the mapserv development effort, but following mapserv development would
be a
pain. It would be nicer to do it all together, and make a single
coherent
component infrastructure.
When I imagine a "mapscriptified" OpenEV/ArcView clone with XML
mapfiles as
a standard "view" file format, mapserv using the same XML files to
render
web pages, python with "XML mapfile" objects plugged into Zope, and
some/most/all of the data in PostgreSQL/PostGIS, well, I could just
cry...
One could even make python mapserv COM objects that plug into Office,
but
why go there...
I'll shut up now. THANKS!
Vic
PS: Count me in on the conference if there is one...
On Wed, 2002-05-22 at 11:04, Puneet Kishor wrote:
I have wondered about XML myself, and thought, at times, that it would
be cool to have XML. Now, reading Daniel's reasoning, I must say what
he
says makes sense... besides the cool factor, we have to question what
XML will do for us. XML facilitates inter-application communication...
other than that it is a pain in the ass. If Mapserver is the only
program gonna be reading the mapfile, we can make it whatever we want
it
to, and what it is now is good enough.
However, in the spirit of discussion, there is one area where XML might
be helpful. Most code editors (Homesite, jEdit, Pepper) nowadays can
parse XML to create an XML tree. This can make editing a complex
Mapfile
easier as one can check for node closures, correctness and
completeness.
Other than that, I don't see any great advantage to XML.
pk/
On Wednesday, May 22, 2002, at 07:19 AM, Daniel Morissette wrote:
> C F wrote:
>> It seems that this and many other problems I encounter could be
solved
>> by
>> making the .map file format XML based. I searched the archives and
>> have
>> seen quite a bit of discussion on it but I didn't a conclusion. The
>> benefit
>> for me being that I could download and easily parse and retrieve
any
>> information I needed using XPath. Is this being considered at all?
>> If so,
>> I'd be happy to contribute to the discussion and development
>> (wherever I
>> could, but I don't know the C language yet) if that would help. A
>> combination of an XML mapfile, XSLT templates and XPath extremely
>> powerful
>> compared the current template files.
> I think that Steve has been considering a switch to XML eventually,
but
> I don't think there is any formal plan.
> I agree that XML might give more flexibility to the user by allowing
him
> to read the mapfile from external tools, but it would be at the cost
of
> performance (i.e. speed) when parsing the mapfile for every request.
> Combine this loss of performance with the fact that XML would be
harder
> to edit manually than the current format, and you know where I stand
> personally.
> I'm not saying that if we were redesigning from scratch I wouldn't
> consider XML (we use it a lot in other apps), but since we've
already
> got a very good (fast and simple) mapfile format then I won't be the
one
> initiating a switch to XML mapfiles.
> Note that MapScript already gives you access to almost every piece
of
> information from the mapfile, so when the CGI cannot do what you
need
> then the logic path is to switch to MapScript, and then sky is the
> limit.
> My 0.02$
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
