[mapserver-users] 3.7
Paul Ramsey
pramsey at refractions.net
Fri May 24 13:27:37 EDT 2002
If you look at the ./configure --help closely, you'll note that the
--with-postgis parameter actually takes the path to pg_config as the
parameter, not the path to any install directories. pg_config is then
responsible for telling configure exactly where to find libraries and
includes.
Incidentally, you'll need to ensure that the directory of your libpq.so
is either in LD_LIBRARY_PATH (solaris) or listed in /etc/ld.so.conf
(linux)
randy james wrote:
> When defining my install dir for postgres do i use the
> directory for the source code or the dir where the
> include files were installed? (/usr/local/include)
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
