[mapserver-users] Re: Shadow below map
Stephen Woodbridge
woodbri at swoodbridge.com
Tue May 28 20:55:16 EDT 2002
I'm not sure you can do a shadow, but you might be able to by using an
OUTLINESYMBOL that is offset from 0,0 like:
symbol
name 'offset'
type vector
points
0 0 1 -1
end
end
layer
name 'county'
type polygon
data ...
class
symbol 'offset'
size 5
color 85 85 85 # gray
overlaysymbol 'circle'
overlaycolor 255 255 255 # white
overlayoutlinecolor 0 0 0 # black
end
end
OK, I haven't tried this, but the idea is that we lay down a polygon
using the offset symbol which is a 45 degree line to the right in gray.
It is size 5 so the diagonal will be 7 pixels. Then we lay down a white
polygon that is not offset, and we outline the white polygon in black.
Let us know if it works.
-Steve
allan panitch wrote:
> Is there any simple way to make a shadow under the boundry of a map?
> IE.. we have a county map that we just want to make it look like there is
> a shadow below the county (there is nothign around it) or make it look
> raised?
> Thanks for the help.
