[mapserver-users] Re: Shadow below map
Richard Greenwood
rich at GreenwoodMap.com
Tue May 28 22:32:06 EDT 2002
I think Stephen's idea is more elegant (if it works) but a brute force
approach might be to make a new shape file of your county boundary. Then
scoot it southeast a little, add it into your .map file under your real
county boundary and make it some dark color. This assumes that your real
county boundary is a solid filled polygon, which would mask out this
"shadow" polygon.
Rich
At 08:55 PM 5/28/2002 -0400, you wrote:
>I'm not sure you can do a shadow, but you might be able to by using an
>OUTLINESYMBOL that is offset from 0,0 like:
>symbol
> name 'offset'
> type vector
> points
> 0 0 1 -1
> end
>end
>layer
> name 'county'
> type polygon
> data ...
> class
> symbol 'offset'
> size 5
> color 85 85 85 # gray
> overlaysymbol 'circle'
> overlaycolor 255 255 255 # white
> overlayoutlinecolor 0 0 0 # black
> end
>end
>OK, I haven't tried this, but the idea is that we lay down a polygon
>using the offset symbol which is a 45 degree line to the right in gray.
>It is size 5 so the diagonal will be 7 pixels. Then we lay down a white
>polygon that is not offset, and we outline the white polygon in black.
>Let us know if it works.
>-Steve
>allan panitch wrote:
> > Is there any simple way to make a shadow under the boundry of a map?
> > IE.. we have a county map that we just want to make it look like there is
> > a shadow below the county (there is nothign around it) or make it look
> > raised?
> > Thanks for the help.
