[mapserver-users] RE : Proximity Search
Pedro A. Carrasco
pcarrasco at iver.es
Wed May 29 12:46:30 EDT 2002
> Yes, point queries allow you to do this. You set tolerance values for
> each layers and can even set the
> tolerance units. So for malls you could set a tolerance of 5 km and for
> gas stations 2 km and then do
> a standard point query that would use those tolerances as appropriate.
Hello, I try that and works fine, but, is there a method to know the
distance between the point used for the search and the match of that search?
Thanks in advance
Pedro A. Carrasco Ponce
IVER Sistemas de Información Geográfica
Dpto. Técnico
C/Salamanca, 50
46005 Valencia
Telf: +34 96 316 34 00
Fax: +34 96 316 2716
mail : pcarrasco at iver.es
web : http://www.iver.es
