[mapserver-users] truetype as mirrow
    Patricio Gigoux
    pgigoux at munistgo.cl
    Wed May 29 13:00:13 PDT 2002
Hello
I am using  freetype-2.0.3-7 from RedHat7.2
Thanks
Patricio
El Mié 29 May 2002 15:50, Stephen Woodbridge escribió:
> What version of libttf are you using or are you using freetype? I think
> freetype as some problems.
> -Steve
> Patricio Gigoux wrote:
> > hello
> > Do you know, why truetype is display as mirrow when line is vertical?
> > LAYER
> >   NAME nomc
> > #  MAXSCALE 600000
> >   TYPE ANNOTATION
> >   STATUS ON
> >   DATA nive1_ejes   #text-calle
> >   LABELITEM "Nom_siu"
> >   CLASSITEM 'nom_siu'
> >   CLASS
> >     EXPRESSION /./
> >     COLOR -1 -1 -1
> >     LABEL
> >       COLOR 0 0 0
> >       ANGLE AUTO
> >       OFFSET 704 0
> >       BUFFER 2
> > #      FORCE TRUE
> >       FONT "arial"
> >       MAXSIZE 16
> >       MINDISTANCE 15
> >       MINSIZE 3
> > #      PARTIALS TRUE
> >       SIZE 8
> >       TYPE TRUETYPE
> > #      TYPE BITMAP
> > #      SIZE SMALL
> >       POSITION UC
> > #      PARTIALS FALSE
> >     END
> >   END
> >   HEADER "ejes_header.html"
> >   FOOTER "ejes_footer.html"
> >   TOLERANCE 5
> > END
> > thanks in advance
> > Patricio
More information about the MapServer-users
