[mapserver-users] truetype as mirrow
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 29 16:56:30 EDT 2002
Patricio,
I think that is the problem. You will have to install freetype-1.3.1 and
make sure you build gd and mapserver with it and NOT the 2.0 version.
-Steve
Patricio Gigoux wrote:
> Hello
> I am using freetype-2.0.3-7 from RedHat7.2
> Thanks
> Patricio
> El Mié 29 May 2002 15:50, Stephen Woodbridge escribió:
> > What version of libttf are you using or are you using freetype? I think
> > freetype as some problems.
> > -Steve
> > > hello
> > > Do you know, why truetype is display as mirrow when line is vertical?
> > > LAYER
> > > NAME nomc
> > > # MAXSCALE 600000
> > > TYPE ANNOTATION
> > > STATUS ON
> > > DATA nive1_ejes #text-calle
> > > LABELITEM "Nom_siu"
> > > CLASSITEM 'nom_siu'
> > > CLASS
> > > EXPRESSION /./
> > > COLOR -1 -1 -1
> > > LABEL
> > > COLOR 0 0 0
> > > ANGLE AUTO
> > > OFFSET 704 0
> > > BUFFER 2
> > > # FORCE TRUE
> > > FONT "arial"
> > > MAXSIZE 16
> > > MINDISTANCE 15
> > > MINSIZE 3
> > > # PARTIALS TRUE
> > > SIZE 8
> > > TYPE TRUETYPE
> > > # TYPE BITMAP
> > > # SIZE SMALL
> > > POSITION UC
> > > # PARTIALS FALSE
> > > END
> > > END
> > > HEADER "ejes_header.html"
> > > FOOTER "ejes_footer.html"
> > > TOLERANCE 5
> > > END
> > > thanks in advance
> > > Patricio
