[mapserver-users] Persistent Selection
Frank Koormann
frank.koormann at intevation.de
Thu May 30 03:42:33 EDT 2002
* Stephen Woodbridge (woodbri at swoodbridge.com) [020529 04:02]:
> You need to look at the CGI Reference. There are two cgi variables:
> savequery and queryfile that let you do this. Sorry, I can be more
> specific, I use mapscript :)
An alternative is to use a specific layer for visualising the selection.
This requires a primary key in the layer attributes, so once identified
you can visualise the selction using something like:
<input type="hidden" name="map_selection_class_expression"
value="[map_objhilite_class_expression]">
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
