[mapserver-users] Mapserver on a shared server
Puneet Kishor
pkishor at GeoAnalytics.com
Thu May 30 10:27:10 EDT 2002
There are no dumb questions (well, there are a few, but this ain't it) ;-)
> -----Original Message-----
> From: David Bain [mailto:pigeonflight at yahoo.co.uk]
> Sent: Wednesday, May 29, 2002 9:51 PM
> To: Puneet Kishor
> Subject: RE: [mapserver-users] Mapserver on a shared server
> Maybe it's dumb question (I should probably just go
> out and try it) but what about the whole compilation
> stuff?
yes, the whole compilation stuff is a problem... esp. given all the
dependencies. If perchance your dev box were identical to your ISP's, you
could compile on your box and then install the binary(s) on the webserver,
and cross your pinky that it works. This is the curse of the diversity in
Unix world (unless you and your ISP are running MacOS X... say it's so :)
try colo... that way you can own your box and do what you want with it, and
when it is all working, stuff it in your colocator's cage for a couple of
hundred a month.
good luck.
pk/
> --- Puneet Kishor <pkishor at geoanalytics.com> wrote: >
> yes, it is possible to run Mapserver on a shared
> > webserver, provided your
> > ISP allows you to install your own CGI (mapserv, in
> > this case), and, if
> > required by your application, other accouterments
> > such as
> Perl/PHP/Python/Tcl/MySQL/Postgres/whateveryourheartdesires.
> > that, I am assuming, is what you want to know when
> > you ask "Is it possible
> > to run Mapserver on a shared webserver?"
> > pk/
> > > Sent: Wednesday, May 29, 2002 8:10 PM
> > > To: mapserver-users at lists.gis.umn.edu
> > > Subject: [mapserver-users] Mapserver on a shared
> > server
> > > Is it possible to run Mapserver on a shared
> > webserver?
> > > I have shell access, but I wanted to know if
> > anyone
> > > had successfully done such a thing.
> > > David Bain
> > > Internet and Networking
> > > http://dbain.com
> > > T http://www.jaFinD.com T
> > > T find Jamaican Properties T
> > > L__ for Sale or for Rent ___T
> > > __________________________________________________
> > > Do You Yahoo!?
> > > Everything you'll ever need on one web page
> > > from News and Sport to Email and Music Charts
> > > http://uk.my.yahoo.com
> David Bain
> http://dbain.com
> Do You Yahoo!?
