[mapserver-users] Instalation problems...
Dragos Lipan
dlipan at pcrai.ro
Mon Nov 4 05:36:53 EST 2002
When trying to install mapserver 3.6.1,
after all necesary prerequisites,
I found for
./configure --with-gd=/usr --with-postgis --with-gdal --with-proj \
--with-ogr --with-wmsclient
the following
loading cache ./config.cache
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for c++... (cached) c++
checking whether the C++ compiler (c++ ) works... yes
checking whether the C++ compiler (c++ ) is a cross-compiler... no
checking whether we are using GNU C++... (cached) yes
checking whether c++ accepts -g... (cached) yes
checking for ranlib... (cached) ranlib
checking for flex... (cached) flex
checking for yywrap in -lfl... (cached) yes
checking for bison... (cached) bison -y
checking if compiler supports -R... (cached) no
checking if compiler supports -Wl,-rpath,... (cached) yes
checking for exp in -lm... (cached) yes
checking how to run the C preprocessor... (cached) gcc -E
checking for ANSI C header files... (cached) yes
checking for strcasecmp... (cached) yes
checking for strncasecmp... (cached) yes
checking for strdup... (cached) yes
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
checking which version of GD to use...
using libgd from -L/usr/lib -lgd
checking where FreeType is installed...
checking for FT_Init_FreeType in -lfreetype... yes
using libfreetype -lfreetype from system libs.
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... yes
using libpng from system libs.
checking for gdImageGif in -lc... no
checking for gdImagePng in -lc... no
checking for gdImageJpeg in -lc... no
checking for gdImageWBMP in -lc... no
checking for gdImageStringFT in -lc... no
checking for gdImageStringTTF in -lc... no
checking for gdImageString16 in -lc... no
checking for gdImageGifPtr in -lc... no
using GD ( -DUSE_GD_SWAP_XY) from /usr.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... (cached) no
libpdf not found... PDF support not included.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
using libtiff from system libs.
checking whether we should include EPPL7 support...
including EPPL7 support.
checking whether we should include PROJ.4 support...
checking for pj_init in -lproj... yes
checking for pj_transform in -lproj... yes
checking for pj_latlong_from_proj in -lproj... yes
using PROJ.4 from system libs.
checking whether we should include thread safe support...
thread safe support disabled.
checking whether we should include ESRI SDE support...
ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
MPATROL support not requested.
checking whether we should include OGR support...
checking for gdal-config... (cached) /usr/local/bin/gdal-config
checking for OGRRegisterAll in -lgdal.1.1... (cached) yes
using OGR from system libs.
checking if GDAL support requested... yes
checking if PostGIS support requested... yes
checking for pg_config... (cached) /usr/local/pgsql/bin/pg_config
yes, user supplied pg_config
checking if OracleSpatial support requested... no
checking whether we should include WMS support...
OGC WMS compatibility enabled (-DUSE_WMS).
checking whether we should include WMS Client Connections support...
checking for libwww-config... (cached) /usr/local/bin/libwww-config
found libwww version 5.4.0
OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
checking for potential conflict between system regex and rxposix...
checking for regexec in -lrx... (cached) no
Compiling with -DIGNORE_MISSING_DATA.
checking whether we should enable debug features...
checking for PHP/MapScript module options...
PHP/MapScript module not configured.
creating ./config.status
creating Makefile
but make ... resulsts as
gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS -DUSE_WMS_LYR -DUSE_TIFF -DUSE_JPEG
-DUSE_GD_SWAP_XY -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS
-I/usr/include -I/usr/local/include -I/usr/local/include
-I/usr/local/pgsql/include -I/usr/local/include
-I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H shp2img.o -L. -lmap
-L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz -ltiff -ljpeg -lfreetype
-lpng -lz -lproj -ljpeg -L/usr/local/lib -lgdal.1.1
-L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lwwwxml -lxmltok
-lxmlparse -lwwwinit -lwwwapp -lwwwhtml -lwwwtelnet -lwwwnews -lwwwhttp
-lwwwmime -lwwwgopher -lwwwftp -lwwwfile -lwwwdir -lwwwcache -lwwwstream
-lwwwmux -lwwwtrans -lwwwcore -lwwwutils -lmd5 -ldl -lm -o shp2img
/usr/lib/libwwwapp.so: undefined reference to `HTZLib_inflate'
/usr/lib/libgd.so: undefined reference to `XpmReadFileToXpmImage'
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
HTZLib_inflate I can avoid,
but I really can't do anything with libgd.so ..
Any ideas?
TIA
Dragos Lipan
TI
Parcul National Piatra Craiului
2223 Zarnesti
Str. Raului. 27
Tel/fax (04)(068)223008
dlipan at pcrai.ro
