[mapserver-users] Couldn't run perl mapscript under Apache
Puneet Kishor
pkishor at GeoAnalytics.com
Thu Nov 7 10:48:03 EST 2002
On Thursday, November 7, 2002, at 05:45 AM, Krung Saengpole wrote:
> Hello all,
> I had trouble getting perl mapscript run on Apache 1.3.26 under RH
> 7.2. Mapscript compiled from mapserver 3.6.3.
> My script is:
> #!/usr/bin/perl
> use mapscript;
> use CGI qw/:standard/;
> print header();
> print start_html();
> $map = new mapObj('mapfile.map');
> $img = $map->draw(); # <---- error took place here
> $img->saveImage('file.png', $mapscript::MS_PNG,1,1,0);
well, you have tell us what the error message was.
The code looks ok to me except I would separate the logic and the
output... y'know, do all the image generation, and only then start with
my print header etc.
