[mapserver-users] problem with itemquery
Martin Hoegh
mh at svaj.dk
Fri Nov 8 05:28:20 EST 2002
Hello
I have worked with MapServer quite a while now and find it very useful. But I have a problem which I can not solve. I am using ms to generate an image in an html image tag, very simple:
The url looks like this:
http://localhost/scripts/mapserv.exe?map=../wwwroot/langeland/langeland.map&mode=itemquerymap&qlayer=savebygninger&layers=savebygninger&map_savebygninger_filteritem=id&map_savebygninger_filter=%273440%27&mapxy=shape&IMGSIZE=500+500
and layer definition:
LAYER
NAME savebygninger
TYPE polygon
STATUS on
DATA save_bygninger_pol_region_s34
METADATA
"DESCRIPTION" "savebygninger"
"RESULT_FIELDS" "ID"
END
CLASS
name savebygninger
TEMPLATE "ttt"
SIZE 7
COLOR 255 0 0
END
END
And the result:
msQueryByAttributes(): Search returned no results. No matching record(s) found, layer and area of interest do not overlap.
This can not be true, I have checked every thing and it works fine with mode=map but not mode=itemquerymap. The url works fine with other shp-files.
What could be wrong? Could it be something with the shp-file? It does not seem to be corrupted.
I am using MS 3.6.3, win2000 IIS.
/Martin Hoegh
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021108/2294902a/attachment.html
