[mapserver-users] Debian ?
Eric L. Blevins
eblevins at insight.rr.com
Fri Nov 8 14:18:54 EST 2002
We had similar problems when installing, some of our packages like PHP
were installed from RPM (RedHat 8.0) system.
We found the best thing to do is remove any pre-installed packages.
Then compile each package from the source code.
This way you can specify the options you need to the configure script
and get everything up and running.
It is not too much more work to compile from source, just read the
documents for each package.
Good luck!
Eric L. Blevins
www.WiFiMaps.com
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, November 08, 2002 11:15 AM
Subject: [mapserver-users] Debian ?
> Hi, I am pretty new to linux, I am trying to set up mapserver with
> php-mapscript under debian (woody 3.0 install)
> My problem is that I get an error which says that I need to recompile
> php with --system-regex I think it was as it was complaining that php4's
> regex was bad.
> I am sorry about the vagueness of this, but I have been at this 25+
> hours straight and it will take a bit of digging to get back to where I
> was. (I trashed the file system baaaad)
> Under debian, I am using an install program (apt-get) to install stuff
> rather than using makefiles, so I don't have control of the options
> passed to the ./config script I don't think. Can anyone point me in the
> direction of somewhere that may explain this please ?
