[mapserver-users] Couldn't run perl mapscript under Apache
krung
krung at cad.go.th
Sun Nov 10 07:05:09 PST 2002
Puneet
As I told you last message, error_log showed no cause except "[Sun Nov 10 22.04.55] [error] [client 127.0.0.1] Premature end of script headers: /map/testmap.pl".
I didn't know if I checked for error line correctly. I script it:
use mapscript;
use CGI qw/:standard/;
print header();
$map = new mapObj("mapfile.map") or print "couldn't open map file\n";
unless ($map) { exit;}
print 'OK';exit; <-- this line for checking openning map file and be removed if it prints.
$img = $map->draw() or print "images couldn't be drawn\n";
unless ($img) { exit;}
In line "print 'OK';exit;", I used it to check if openning mapfile had error. It printed 'OK', so it could open mapfile. Then I removed it out and re-run the script. It showed "Internal Server Error" to my browser. Error message I got from error_log in /etc/httpd/logs/error_log and /var/log/httpd/error_log was that I showed you in the beginning of this message. I didn't know what and how to solve this trouble.
Thank you
Krung.
---------- Original Message ----------------------------------
Date: Sat, 9 Nov 2002 19:36:00 -0600
>On Saturday, November 9, 2002, at 11:09 AM, krung wrote:
>> Hi Lowell, Puneet
>> I tried as you told me. If I ran with command line, mapserver.log was
>> created whem error occured. But when run on Apache, mapserver's never
>> created as error occured. (access right with this directory'd set to
>> 777 already) So I checked it at error_log of httpd log file, but it's
>> non-sense to me. It showed only "Premature of script headers:
>> /usr/mapserver/testmap.pl".
>> And I tried to change script logic flow as you, Puneet, told me. It's
>> the same error as before (Internal Server Error).
>Krung,
>You really have to tell us what the error is. The "Internal Server
>Error" is the end result. Usually, that end result is the result of one
>or more errors happening in tandem. Do the following (assuming your
>apache log is under /var/log/httpd/)... type "tail -f
>/var/log/httpd/error_log". This will output the last few lines of the
>log file on your stdout, and keep the handle open. Now run your
>mapserver script via the web server. You will see the tail output
>change. Copy the lines that were outputted as a result of your last
>attempt to load the mapserver page. Mail that to the list. Then we will
>know better what is going on.
>Another question. In your message you say
>>>> $img = $map->draw(); # <---- error took place here
>How do you know that the error took place there? Usually the script
>breaks because of an error before the break.
>Again, send us all the error messages. Only then can we help.
>I am assuming that perl runs fine as cgi on your computer otherwise.
>pk/
>> Do I have to specially configure when I create mapserver program? Any
>> comments, help, advice would be graceful.
>> Thank you
>> Krung
>> From: "Lowell Filak"<lfilak at medinaco.org>
>> Date: Thu, 07 Nov 2002 08:24:06 -0500
>>> You can try adding the line noted below and see if a file
>>> mapserver.log exists in the current directory and if it reports an
>>> error.
>>> If the mapserver.log file isn't created then try changing the path of
>>> the log file to somewhere writeable by the apache process.
>>> HTH
>>> Lowell F.
>>> The following message was sent by "Krung Saengpole" <krung at cad.go.th>
>>> on Thu, 7 Nov 2002 18:45:20 +0700.
>>>> Hello all,
>>>> I had trouble getting perl mapscript run on Apache 1.3.26 under RH
>>>> 7.2. Mapscript compiled from mapserver 3.6.3.
>>>> My script is:
>>>> #!/usr/bin/perl
>>>> use mapscript;
>>> $ENV{MS_ERRORFILE} = "mapserver.log"; <--Try adding this line.
>>>> print header();
>>>> print start_html();
>>>> $map = new mapObj('mapfile.map');
>>>> $img->saveImage('file.png', $mapscript::MS_PNG,1,1,0);
>>>> What I did wrong with this script or anything else? But I could run
>>>> this script at command line. I'm very new to Linux. I tried to write
>>>> a script that open database and run under Apache, it had no problem.
>>>> So, I thought it should not be wrong with Apache configuration.
>>>> Thank you in advance.
>>>> Krung.
More information about the MapServer-users
