[mapserver-users] Mapplet problems.
Richard Greenwood
Rich at greenwoodmap.com
Mon Nov 11 18:09:45 EST 2002
I'm guessing that maybe Java is disabled in your browser. (Check Tools,
Security, Custom Level, Scripting). Or try another browser. Or try this site:
http://www2.tetonwyo.org/mapserver and select the Java interface which used
mapplet). Then at least you can tell if it's your browser or your
server/application.
Rich
At 08:59 AM 11/12/2002 +1100, you wrote:
>G'Day All,
>I have only started using MapServ but it is really good to work with. At
>present I am running it on an XP machine with IIS 5.1 and Internet Explorer
>6.0.2. I just download the MapServ Win binarys and it all work fine (with a
>HTML interface). However when I tried to run Mapplet, I keep getting the
>following error,
> exception: com.ms.security.SecurityExceptionEX [mapplet.init]: cannot
>access "localhost":80
>I can't figure it out. It is an XP problem or a Mapplet issue ?? I have
>tried changing a number of things in the demo.html, the demo_init.html, I
>have even gone through the code supplied with Mapplet (I didn't change or
>re-compile it though).
>Any Ideas.
>Tom Bartlett
>----- Original Message -----
>From: "Hankley, Chip" <Chip.Hankley at GASAI.Com>
>To: "Seth Rodriguez" <srodriguez at maguiregroup.com>;
><mapserver-users at lists.gis.umn.edu>
>Sent: Tuesday, November 12, 2002 5:33 AM
>Subject: RE: [mapserver-users] beginner getting started
> > > I am running XP on my machine. Will this be a problem? I can move
> > > to another machine if needed.
> > This shouldn't be a problem. The first thing you need to do is make sure
> > that you have a functioning web service. I'm not an XP person, but Win2K
>Pro
> > gives you the option to install IIS (Internet Information Service) as a
>web
> > server. You could also go through the process of installing Apache (free).
> > Start off by looking up "IIS" in help, and see how to install it.
> > As others have mentioned before, the OS you use is irrelevant. All
>platforms
> > come with their pro's and con's... if you are comfortable working in the
> > windows environment, then stick with that... otherwise you'll be adding
>one
> > more thing to the things you need to figure out.
> > The executables are not bundled with the demo (at least they didn't used
>to
> > be). From the main web site, look under downloads. You will see that there
> > are "pre-compiled binaries" - you should choose one of these. This will
>have
> > an executable (mapserv.exe) - this should get you started.
> > > I hope that I am not biting off too much with this task.
> > There is undoubtedly a learning curve...
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich at GreenwoodMap.com
(307) 733-0203
http://www.GreenwoodMap.com
