[mapserver-users] Couldn't run perl mapscript under Apache
krung
krung at cad.go.th
Fri Nov 15 00:24:54 EST 2002
Lowell.
My script is very simple below;
#!/usr/bin/perl -w
use mapscript;
use DBI qw/:standard/;
print header();
$map = new mapObj("test.map") or die "couldn't open map file\n";
$img = $map->draw();
$img->saveImage("images/test.png", $mapscript::MS_PNG,1,1,0);
print "<IMG SRC=\"images/test.png\">";
Thanks
Krung
---------- Original Message ----------------------------------
Date: Wed, 13 Nov 2002 08:16:42 -0500
>Next idea.
>Please send your script.
>Thanks.
>Lowell F.
>The following message was sent by "krung" <krung at cad.go.th> on Wed, 13 Nov 2002 12:48:01 +0700.
>> Lowell and Puneet,
>> I'd tried switch -w already, the same result. I suspect that my Apache has suexec enabled. It might cause the problem. I'll try to disable it but don't know how to now. I'll try with it.
>> Thank you very much for your help and patience.
>> Krung
>> From: "Lowell Filak"<lfilak at medinaco.org>
>> Date: Tue, 12 Nov 2002 08:32:35 -0500
>> >Okay.
>> >First problem solved.
>> >Now please try adding the -w switch to your script as Puneet has suggested and report what happens.
>> >Lowell F.
>> >The following message was sent by "krung" <krung at cad.go.th> on Tue, 12 Nov 2002 09:18:37 +0700.
>> >> Lowell,
>> >> If I ran at the command line "cat mapserver.log", it showed the error I tend to make in mapfile, e.g. I changed "UNITS KILOMETERS" to "UNITS KILO", it showed that it didn't know "KILO". If that mapfile worked without error, no new message's in that log file. And with this error-free script run on Apache, it stoped with "Internal Server Error" with no new message in mapserver.log and at the error_log of Apache, it showed only one line "Premature end of script header:/mapserver/testmap.pl". With this error_log file, I'm very sure it printed out only one line of error per access to this script.
>> >> Thanks
>> >> Krung
